I have IMX568c camera and jetson orin nano (developer kit) with jetpack 5.1.1 (R53.3.1)
I installed the driver from here
I’m using this command to get stream
gst-launch-1.0 nvarguscamerasrc aelock=0 wbmode=1 ! 'video/x-raw(memory:NVMM),width=3820, height=2464, framerate=21/1, format=NV12' ! nvvidconv flip-method=0 ! 'video/x-raw,width=960, height=616' ! nvvidconv ! nvegltransform ! nveglglessink -e
but the color format is wrong. Black colors (chair and my hoodie) looks like purple. Is there any way to convert colors to correct color format?
tegra234-camera-vc-mipi-cam.dtsi properties is below
mode_type = "bayer";
pixel_phase = "rggb";
csi_pixel_bit_depth = "10";
v4l2-ctl -d /dev/video0 --all command output is below
Driver Info:
Driver name : tegra-video
Card type : vi-output, vc_mipi 10-001a
Bus info : platform:tegra-capture-vi:2
Driver version : 5.10.104
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Driver name : tegra-camrtc-ca
Model : NVIDIA Tegra Video Input Device
Serial :
Bus info :
Media version : 5.10.104
Hardware revision: 0x00000003 (3)
Interface Info:
Type : V4L Video
Entity Info:
Name : vi-output, vc_mipi 10-001a
Function : V4L2 I/O
Pad 0x0100000a : 0: Sink
Link 0x0200000f: from remote pad 0x1000006 of entity '13e40000.host1x:nvcsi@15a00000-': Data, Enabled
Priority: 2
Video input : 0 (Camera 2: no power)
Format Video Capture:
Width/Height : 2464/2048
Pixel Format : 'RG10' (10-bit Bayer RGRG/GBGB)
Field : None
Bytes per Line : 4928
Size Image : 10092544
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Selection Video Capture: crop, Left 0, Top 0, Width 2464, Height 2048, Flags:
Selection Video Output: crop, Left 0, Top 0, Width 2464, Height 2048, Flags:
Camera Controls
group_hold 0x009a2003 (bool) : default=0 value=0 flags=execute-on-write
sensor_mode 0x009a2008 (int64) : min=0 max=1 step=1 default=0 value=0 flags=slider
gain 0x009a2009 (int64) : min=0 max=48000 step=100 default=0 value=1000 flags=slider
exposure 0x009a200a (int64) : min=1 max=183022398 step=1 default=10000 value=10025 flags=slider
frame_rate 0x009a200b (int64) : min=0 max=42360 step=1 default=0 value=21000 flags=slider
trigger_mode 0x009a200e (int) : min=0 max=7 step=1 default=0 value=0
io_mode 0x009a200f (int) : min=0 max=5 step=1 default=0 value=0
black_level 0x009a2010 (int) : min=0 max=100000 step=1 default=0 value=0
single_trigger 0x009a2011 (button) : flags=write-only, execute-on-write
sensor_configuration 0x009a2032 (u32) : min=0 max=4294967295 step=1 default=0 [22] flags=read-only, volatile, has-payload
sensor_mode_i2c_packet 0x009a2033 (u32) : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
sensor_control_i2c_packet 0x009a2034 (u32) : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=1
0: 0 (0x0)
1: 1 (0x1)
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=1
0: 0 (0x0)
1: 1 (0x1)
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
0: 1 (0x1)
1: 65536 (0x10000)
2: 131072 (0x20000)
write_isp_format 0x009a2068 (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties 0x009a2069 (u32) : min=0 max=4294967295 step=1 default=0 [30][18] flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=4294967295 step=1 default=0 [30][18] flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=4294967295 step=1 default=0 [30][36] flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
preferred_stride 0x009a206e (int) : min=0 max=65535 step=1 default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=1 flags=read-only
