Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
Hi there,
It seems like IMX490_RGGB_CPHY_x4 configuration file is missing on AGX Xavier platform but it is available on AGX Pegasus (when looking into this and this forum post). How can we can access to missing configuration file?
Thanks,
B.
Hello:
I use IMX490_RGGBCD as camera-name it works.But need nito file for ISP,I use template as ref nito file.
bin
Hi @lb_tusimple
Thanks for the follow up!
Are you using AGX Xavier or AGX Pegasus platform? Also curious which NITO template file are you referring to?
Cheers,
B.
Dear @bogdan0kg3v,
Could you please check with Sony for this issue? The nito file is expected to present at /opt/nvidia/nvmedia/nit/
for nvmedia sample to work.
Hi @lb_tusimple,
would you mind sharing the command line you use for example with the nvsipl_camera
tool from nvidia to run the IMX490? Or do you mean camera-name in form of the --platform-config 'name'
parameter for that tool? Because that does not work in our case it always says:
./nvsipl_camera --platform-config=IMX490_RGGBCD --link-enable-masks="0x0000 0x0000 0x0000 0x0001" --showfps
nvsipl_camera: ERROR: INvSIPLQuery::GetPlatformCfg failed. status: 1
Thank you!
Hello richard5:
I usd DriveWorks to run 4 IMX490 camera sample.
If you use DriveOs sample,just try ./nvsipl_camera --help and pick up the platform name from log:
As far as I remember : -c “IMX490_RGGBCD_x2” or “IMX490_RGGBCD_x4”
bin
Hello bogdan0kg3v:
In my case i do not have IMX490CD_RGGB.nito. and if you use IMX490_RGGB.nito.The program will failed due to some ISP fault.
Just cp /opt/nvidia/nvmedia/nit/template.nito /opt/nvidia/nvmedia/nit/IMX490CD_RGGB.nito ,It works.
I do not know the reason,anyway it just works.but the image is pretty dark.
thanks
bin
Hi @lb_tusimple,
neither IMX490_RGGBCD_x2 nor IMX490_RGGBCD_x4 exist in the nvsipl_camera sample. That is the problem. There aren’t any IMX490 configurations available for that tool.
I will check the driveworks samples then.
Thank you!
