Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
[v] DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Host Machine Version
[v] native Ubuntu 18.04
other
I am running nvspil_camera sample (NO modification). and get errors:
~/drive-t186ref-linux/samples/nvmedia/nvsipl/test/camera$ ./nvsipl_camera --platform-config “SF3324_DPHY_x4” --link-enable-masks “0x0001 0x0000 0x0000 0x0000” -d 0 -w 1
nvsipl_camera: ERROR: ModeSetCrtc failed for mode index 0
nvsipl_camera: ERROR: Unable to get EGLOutput layer
nvsipl_camera: ERROR: Compositor: InitDisplay failed
nvsipl_camera: ERROR: Compositor initialization failed. status: 127
while running sample_camera works as fine
/usr/local/driveworks-4.0/bin$ ./sample_camera rig=’/usr/local/driveworks-4.0/data/samples/sensors/camera/camera/rig.json’
HI @VickNV
The monitor is connected to HDMI as /usr/local/driveworks-4.0/bin$ ./sample_camera works fine.
reading the reference post, executing the sudo pkill X, the monitor is gone as the other shown.
Your suggestion of lost monitor is to “reflash DRIVE OS 5.2.6 and then try it again”, You mean reflash by SDKManager, again?
I haven’t seen the issue so I was asking you to refer to the developer’s experience there.
After “sudo pkill X”, do you still see the same output of your command?
The developer clarified their problem is due to the specific monitor.
running nvsipl_camera after “sudo pkill X” is because the application cannot be run with X enabled. You should be able to see the display output.
What’s your current nvsipl_camera command output (if run after “sudo pkill X”)?
