Model Crashed When Simulating Crawler Robot
Hi, there, I am trying to simlulate the crawler robot, the robot file is from this link: “Is it possible to simulate a tracked robot in ISAAC Sim? - #12 by sebastian.b”. It works well, but I’ve met the problem if I enable the “articulation root” of this crawler, the model will crash at the first step. I have tried to increase the “Max Pos/Vel iteration” and “aggregate pairs” to a very large number, but in vain. I am looking forward to your kind help and reply.
Thanks,
Fuhua
@twidmer hi, twidmer, I hope this message finds you well, I am posting a question related to your work at 2023, hope could get guide from you, thanks.
Hi @suxfj2, thank you for posting your question. I took a look at the attached URDF for the tracked wheels and I am unable to get it to work in Isaac Sim 4.5.0. I think potentially this asset was created some time ago and it is not transferring correctly to 4.5.0. For instance, I don’t find prims with RigidBody properties so physics is not affecting the robot. Do you have a specific crawler robot that you want to use that you may have the URDF for? We can import it from there and I can help with you that. Or in your setup, if you are seeing articulation crash can you be more specific as to which prim you are adding articulation to?
Hello!
Best regards,
