Based on the provided context, it appears that you are trying to modify the raw Bayer data before sending it to the Argus API for processing on a Jetson AGX Orin device.
Historically, it was not possible to pass raw Bayer data stored in memory to the ISP engine in the Argus software stack. The Argus API was designed to capture RAW data from a physical camera sensor and process it through the ISP pipeline.
However, according to the release notes of Argus (Release 0.99.2, 01/24/2023), it seems that there is a new feature that allows reading Bayer raw image frames from disk or a user-provided raw buffer instead of a physical camera sensor. This feature enables the use of the read frames as input to the Image Signal Processor for reprocessing.
Unfortunately, this feature is not explicitly mentioned as being supported on the Jetson AGX Orin device. However, it is possible that it may work, but it is not tested, and there may be potential issues.
In comparison to the Jetson AGX Xavier, it seems that the feature was available on that device, but it was not supported on the Jetson AGX Orin.
In the latest release note of Libargus Camera API (image 1.007.180, 1.05 KB), it is mentioned that the feature has been available for years, but it is still not clear if it is supported on the Jetson AGX Orin device.
In summary, while there is a feature in the Argus API that allows reading Bayer raw image frames from disk or a user-provided raw buffer, it is not clear if this feature is supported on the Jetson AGX Orin device. It may be possible to use this feature, but it is not tested, and there may be potential issues.
To confirm the availability of this feature on the Jetson AGX Orin device, I would recommend checking the official NVIDIA documentation or contacting NVIDIA support for further clarification.
Here is a code example that demonstrates how to use the IFrameProducer interface to present a frame to the Argus API:
// Create an IFrameProducer instance
IFrameProducer* frameProducer = createIFrameProducer();
// Create a raw Bayer buffer
NvBuffer* rawBuffer = createNvBuffer(width, height, NvBufferColorFormat_RAW);
// Fill the raw Bayer buffer with data
// Present the frame to the Argus API
frameProducer->presentFrame(rawBuffer);
Note that this code example is hypothetical and may not work on the Jetson AGX Orin device. It is recommended to check the official NVIDIA documentation and contact NVIDIA support for further clarification.
