I’m running Ubuntu 20.04 with a GEFORECE RTX 2070s graphics card. Since getting a new monitor, my computer has had issues with the resolution and other settings when logging out or restarting the computer. When initially logging back in, everything appears correctly for a couple seconds before both of my monitors go dark, then come back with the primary display (the new monitor, which should be at 2560x1440) being disabled entirely and my secondary monitor (which should appear at 1920x1080) coming back at a severely reduced resolution and refresh rate.
I’m able to restore the proper setting using the “NVIDIA X Server Settings” app, but despite trying to save the settings to the X Config File after making the changes, none of them stick around after being logged out. I’m aware that sometimes there’s a permissions issue with the x config, so I tried a method where I saved the new xconfig somewhere else and used it to overwrite the old one with the command line, but that didn’t seem to fix it either.
I’m about out of ideas, any recommendations are appreciated, thanks.
