Could you please list the steps to get MultiMatte to render as Path Trace AOVs?
Currently I’m not able to render MultiMatte AOVs in Create 2022.3.1 - the result is just black image with each channel being black.
Steps I do to try to render Multimatte:
- Right Click Scene → Create → AOV
- Add Camera in AOV → RenderView
- Select each object → Property → Multimatte ID → set ID (1, 2, 3 for example - each number for each object)
- Render Setting Path Trace → Multimatte → Channel Count 3 → Red 1, Green 2, Blue 3
- Movie Capture → Path Trace → Use Render Product → /Render/RenderView
- Output as EXR, HDR with alpha
- Render Sequence
Tried with adaptive sampling off and on - the AOV file Capture.0001_PtMultiMatte0.exr is just rendered black
