NVSDK_NGX_D3D12_Init() and NVSDK_NGX_D3D12_GetCapabilityParameters(&ngxParameters) succeed but ngxParameters->Get(NVSDK_NGX_Parameter_SuperSampling_Available, &isDLSSAvailable) returns NVSDK_NGX_Result_FAIL_UnsupportedParameter.
I think, this is because the SDK doesn’t find the nvngx_dlss.dll.
I’m getting either
[NGXLoadAndValidateSnippet:1781] nvLoadSignedLibraryW() failed on snippet './nvngx_dlss.dll' missing or corrupted - last error One or more arguments are not correct.
or
[NGXSecureLoadFeature:519] warning: ModuleName - nvngx_dlss.dll doesn't exist in any of the search paths!
in the log, depending on whether I fill out NVSDK_NGX_FeatureCommonInfo.PathListInfo. I’ve copied the DLL to the working directory, to the binary directory, to the directory of the DLL that loads it and added it to PATH. I’ve also tested the sample that comes with the SDK, which works fine. If I delete the DLL from the sample, I’m getting the same behavior.
I’m initializing NGX like this:
const char* paths[] = { // I've also tried backslashes and backslashes at the end
"C:/Programmierung/C++/ExternalLibs/dlss-2_4/lib/Windows_x86_64/dev",
"C:/Programmierung/C++/ExternalLibs/dlss-2_4/lib/Windows_x86_64/rel",
"C:/Programmierung/C++/Private/DLSSTest/bin/x64/Debug DX12",
NVSDK_NGX_FeatureCommonInfo featureCommonInfo = {};
featureCommonInfo.LoggingInfo.LoggingCallback = AppLogCallback;
featureCommonInfo.LoggingInfo.MinimumLoggingLevel = NVSDK_NGX_LOGGING_LEVEL_VERBOSE;
featureCommonInfo.LoggingInfo.DisableOtherLoggingSinks = true;
featureCommonInfo.PathListInfo.Path = const_cast<char**>(paths);
featureCommonInfo.PathListInfo.Length = 4;
NGXCHECK(NVSDK_NGX_D3D12_Init_with_ProjectID(
projectGuid.c_str(),
NVSDK_NGX_ENGINE_TYPE_CUSTOM,
CORELIB_VERSION_STRING,
logPath.c_str(),
renderingWindow->GetDevice().Get(),
&featureCommonInfo,
static_cast<NVSDK_NGX_Version>(0x00000014)
), "Failed to initialize NGX");
but I’ve also tried it the way the sample does:
auto result = NVSDK_NGX_D3D12_Init(
1245561,
L".",
renderingWindow->GetDevice().Get());
NGXCHECK(result, "Failed to initialize NGX");
I don’t understand what I’m doing wrong. Is it not possible to initialize NGX from within a DLL maybe? Does this have something to do with nvLoadSignedLibrary failing to recognize that the library is signed? I’ve tried both the debug and release DLLs.
I’ve attached the entire log.
dlss_log.txt (27.5 KB)
