My tech broke the fan connection, replacements?
My tech somehow lifted the fan off the Xavier and then the connection underneath broke. Is there somewhere I can order just the connector, or the pins, or the fan in general?
The fan header has 4 pins, Pin1 GND, Pin2 5V, Pin3 Fan_tach, Pin4 FAN_PWM.
If the connector broke on carrier board, You could solder the cable to board.
