Nano 00_video_decode dec error
hi all ,now my application print the following errors,but i can not found that log at the src code ,my application is base on the 00_video_decode ,that dec h264 data is form rtsp,but when i restart that the decoder the application can decode normally ,my question is where that following error print, and how can i do to fix the error
NVMEDIA: NvMMLiteNVMEDIADecDoWork: 1982: NVMEDIA Video Dec Unsupported Stream
NVMEDIA: NVMEDIABufferProcessing: 1504: NvMediaParserParse Unsupported Codec
It is more like an issue in the h264 stream. Looks like it is broken. Suggest you inspect validness of the stream through ffmpeg or JM decoder first.
hi Danelll ,thanks for your help ,that error is not always appear,for now it just appear one time ,so i just want to know how to fix it in the application if that error appear ,because i can not catch the error in the program source code
When you see the error, you would need to re-create NvVideoDecoder. Please check this post:
hi Danelll, the problem is that i do not know when the error occur,and in the source code can not catch the error so i can restart the decoder,now i just can restart the decoder when the test engineer discover the error then tell me
Do you have the broken stream so that we can reproduce it by running 00_video_decode? Please attach it if you have any. We can reproduce it and check to have an error-handling solution.
