Nano 2GB dosent power up using USB power
Hi, I am using Nano 2Gb , My Boards USB C type source seem to be not working, I need help How can I power up this board using GPIO?
Hi, you can check your board following the devkit user guide first. Jetson Nano 2GB Developer Kit User Guide | NVIDIA Developer
If you have good hardware knowledge you can check type c part on board to see if any board issue following the carrier board schematic. Or you can run RMA for it directly.
