Jetson Nano 2GB was working fine. Powered off and will not power back on. Power supply switching has not solved the problem. There are no LEDs that power on when power is supplied to the board. I reached out to NVIDA customer support and they sent me here. Is there any other option to power the board? Power is being supplied through USB-C by a NorthPadaPower Supply Charger AC Adapter 5V 3A PSU USB Type C 4 Feet with On/Off Power Switch.
WayneWWW
3
Do you have other jetson nano devices to verify this is not the power adapter issue but only to one device?
Yes. The power supply works fine with other boards.
Related topics
| Nvidia Jetson Nano 2 GB : doesn't light on | 2 | 535 | October 15, 2021 | |
| Jetson nano 2gb not boot when power supply on GPIO | 6 | 1033 | October 15, 2021 | |
| Jetson intermittent barrel jack power problems | 4 | 1214 | October 15, 2021 | |
| Jetson Nano 2GB Devkit not powering on correctly | 3 | 722 | January 30, 2022 | |
| Jetson nano 2GB power supply problem: green light turn off after 1 seconds on | 11 | 1975 | March 3, 2022 | |
| Jetson Nano 2GB not turning on | 2 | 654 | October 15, 2021 | |
| Jetson Nano developer kit not working | 4 | 701 | March 3, 2022 | |
| Is my USB power supply broken or my Jetson Nano broken? | 7 | 1732 | October 18, 2021 | |
| Jetson Nano 2GB dev kit doesn't turn on : Power LED turns on and turn off in 1sec | 5 | 1097 | February 23, 2022 | |
| I broke my usb-c connector in nano | 8 | 685 | January 19, 2022 |
