I am using jetson nano 2gb for the first time. I connected power supply(s) to GPIO pins.
Whenever I switch on the board from the green LED is turned ON and automatically it gets shutdown in a few seconds.
I tried with multiple power supplies same result. (greend led is switch off after few seconds)
- 2.4 A usb charger
- powerbank
- 5v 30 A led power supply
When I connected led power supply to usb-c, the board booting fine.
What is the difference between the two inputs? What could be the problem when the GPIO gets power from the board?
Thanks and Regards,
Gyula
My serial logs when the board not boot:
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-80a468da)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 1
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x314e4
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x00000000bf300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] Read GPT from (4:0)
[0000.493] Csd NumOfBlocks=243728384
[0000.497] Set High speed to 1
[0000.507] Using GPT Primary to query partitions
[0000.512] Loading Tboot-CPU binary
[0000.521] Verifying TBC in OdmNonSecureSBK mode
[0000.531] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.538] Bootloader downloaded successfully.
[0000.542] Downloaded Tboot-CPU binary to 0xa0000258
[0000.547] MAX77620_GPIO5 configured
[0000.550] CPU power rail is up
[0000.553] CPU clock enabled
[0000.557] Performing RAM repair
[0000.560] Updating A64 Warmreset Address to 0xa00002e9
[0000.565] Read GPT from (4:0)
[0000.574] Using GPT Primary to query partitions
[0000.578] Loading NvTbootBootloaderDTB
[0000.603] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.682] Bootloader DTB Load Address: 0x83000000
[0000.686] Read GPT from (4:0)
[0000.695] Using GPT Primary to query partitions
[0000.699] Loading NvTbootKernelDTB
[0000.724] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.803] Kernel DTB Load Address: 0x83100000
[0000.807] Read GPT from (4:0)
[0000.815] Using GPT Primary to query partitions
[0000.820] Loading cboot binary
[0000.850] Verifying EBT in OdmNonSecureSBK mode
[0000.891] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.898] Bootloader downloaded successfully.
[0000.903] Read GPT from (4:0)
[0000.911] Using GPT Primary to query partitions
[0000.916] Read PT from (2:0)
[0000.931] Using BFS PT to query partitions
[0000.935] PT: Partition NCT NOT found !
[0000.939] Warning: Find Partition via PT Failed
[0000.943] Next binary entry address: 0x92c00258
[0000.948] BoardId: 3448
[0000.952] Overriding pmu board id with proc board id
[0000.957] Display board id is not available
[0000.961] Read GPT from (4:0)
[0000.970] Using GPT Primary to query partitions
[0000.998] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.056] /bpmp deleted
[0001.059] SC7EntryFw header found loaded at 0xff700000
[0001.251] OVR2 PMIC
[0001.253] Bpmp FW successfully loaded
[0001.257] Read GPT from (4:0)
[0001.268] Using GPT Primary to query partitions
[0001.273] WB0 init successfully at 0xff780000
[0001.278] Set NvDecSticky Bits
[0001.281] GSC2 address ff53fffc value c0edbbcc
[0001.288] GSC MC Settings done
[0001.290] Read GPT from (4:0)
[0001.299] Using GPT Primary to query partitions
[0001.304] TOS Image length 53680
[0001.307] Monitor size 53680
[0001.310] OS size 0
[0001.317] Secure Os AES-CMAC Verification Success!
[0001.322] TOS image cipher info: plaintext
[0001.325] Loading and Validation of Secure OS Successful
[0001.341] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.346] NvTbootPackSdramParams: start.
[0001.351] NvTbootPackSdramParams: done.
[0001.355] Tegraboot started after 52319 us
[0001.359] Basic modules init took 945713 us
[0001.363] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0001.368] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.374] Storage Device Read Time = 126 ms, Read Size = 2359 KB
[0001.380] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.385] Next stage binary read took 24607 us
[0001.389] Carveout took -49418 us
[0001.392] CPU initialization took 414578 us
[0001.396] Total time taken by TegraBoot 1335480 us
[0001.401] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):de895fd9e
NOTICE: BL31: Built : 12:23:48, Oct 16 2020
ERROR: Error initializing runtime service trusty_fast
[0001.523] RamCode = 1
[0001.527] LPDDR4 Training: Read DT: Number of tables = 2
[0001.532] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.545] EMC Training Successful
[0001.548] 408000 not found in DVFS table
[0001.555] RamCode = 1
[0001.558] DT Write: emc-table@204000 succeeded
[0001.564] DT Write: emc-table@1600000 succeeded
[0001.568] LPDDR4 Training: Write DT: Number of tables = 2
[0001.614]
[0001.615] Debug Init done
[0001.618] Marked DTB cacheable
[0001.621] Bootloader DTB loaded at 0x83000000
[0001.626] Marked DTB cacheable
[0001.629] Kernel DTB loaded at 0x83100000
[0001.633] DeviceTree Init done
[0001.645] Pinmux applied successfully
[0001.650] gicd_base: 0x50041000
[0001.653] gicc_base: 0x50042000
[0001.656] Interrupts Init done
[0001.660] Using base:0x60005090 & irq:208 for tick-timer
[0001.666] Using base:0x60005098 for delay-timer
[0001.670] platform_init_timer: DONE
[0001.673] Timer(tick) Init done
[0001.677] osc freq = 38400 khz
[0001.681]
[0001.682] Welcome to L4T Cboot
[0001.685]
[0001.686] Cboot Version: 00.00.2018.01-t210-4686ce50
[0001.691] calling constructors
[0001.694] initializing heap
[0001.697] initializing threads
[0001.700] initializing timers
[0001.703] creating bootstrap completion thread
[0001.707] top of bootstrap2()
[0001.710] CPU: ARM Cortex A57
[0001.713] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.718] initializing platform
[0001.725] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.730] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.734] Macronix QSPI chip present
[0001.738] SPI device register
[0001.740] init boot device
[0001.743] allocating memory for boot device(SPI)
[0001.748] registering boot device
[0001.757] sdmmc node status = okay
[0001.760] sdcard instance = 0
[0001.763] sdcard gpio handle 0x5a
[0001.766] sdcard gpio pin 0xc9
[0001.769] sdcard gpio flags 0x0
[0001.772] vmmc-supply 0x9d
[0001.775] Instance: 0
[0001.777] Allocating memory for context
[0001.781] enabling clock
[0001.783] sd card init
[0001.786] Check card present and stable
[0001.789] Send command 0
[0001.806] Send command 3
[0001.810] Set RCA for the card
[0001.813] Query card specific data by command 9
[0001.819] Parse CSD data
[0001.822] Send command 7
[0001.832] Calling sd device register
[0001.836] Init sdcard
[0001.838] Allocating memory for boot device
[0001.842] Registering user device
[0001.855] Enable APE clock
[0001.858] Un-powergate APE partition
[0001.861] of_register: registering tegra_udc to of_hal
[0001.866] of_register: registering inv20628-driver to of_hal
[0001.872] of_register: registering ads1015-driver to of_hal
[0001.877] of_register: registering lp8557-bl-driver to of_hal
[0001.883] of_register: registering bq2419x_charger to of_hal
[0001.889] of_register: registering bq27441_fuel_gauge to of_hal
[0001.900] gpio framework initialized
[0001.904] of_register: registering tca9539_gpio to of_hal
[0001.909] of_register: registering tca9539_gpio to of_hal
[0001.915] of_register: registering i2c_bus_driver to of_hal
[0001.920] of_register: registering i2c_bus_driver to of_hal
[0001.926] of_register: registering i2c_bus_driver to of_hal
[0001.931] pmic framework initialized
[0001.935] of_register: registering max77620_pmic to of_hal
[0001.940] regulator framework initialized
[0001.944] of_register: registering tps65132_bl_driver to of_hal
[0001.950] initializing target
[0001.956] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.964] board ID = D78, board SKU = 3
[0001.968] Skipping Z3!
