NANO 2GB + Raspi HQ Camera IMX477 not working when SPI is enabled with JETSON-IO.PY utility
My Raspberry Pi HQ Cam IMX477 stops working when I enable the SPI ports with the JETSON-IO.PY utility.
Camera works before using JETSON-IO.PY.
After using JETSON-IO.PY to enable SPI1 and reboot, camera doesn’t work. NVARGUS says no camera.
Editing /boot/extlinux/extlinux.conf and reverting to “primary” kernel without referencing the custom dtb file gets the camera working again.
My Current setup is:
Jetson Nano 2gb Dev Kit
Raspberry Pi HQ Camera IMX477 with latest patch installed from Nvidia website
I want to use the HQ Camera with other SPI devices. How can I get both the HQ Camera and SPI ports working?
Thank you in advance for any help!
Duplicated with: Nano 2gb + Jetpack 4.5 + Raspi HQ Camera IMX477 not working
This is not a duplicate issue to “IMX477 not working”, I am having the same issue as well. When jetson-io.py is used it overwrites /boot/extlinux/extlinux.conf with its own configuration and then cannot use the IMX477.dtb for the camera.
