NanoOWL vs PeopleNet
I am undertaking a multi-company project to create a UAV prototype for surveillance and security of a restricted area and visual inspection of telecommunications infrastructures. My role in the project is to develop the AI component for intrusion detection and the visual analysis of infrastructures.
I decided to use your NVIDIA Jetson Orin Nano Developer Kit. I was studying/researching possible intrusion detection algorithms when I discovered that you have NanoOWL and PeopleNet. However, I wasn’t sure of the differences between them. Can anyone explain the differences between the two? How could I then train the algorithms? Do you also have software to adapt the code to my project/objectives?
Welcome to the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
My question is regarding the differences between NanoOWL and PeopleNet. Even so, should be moved to Jetson Category?
I don’t know of a better location for your topic. The Jetson folks will know for sure.
PeopleNet is a pure detection model and can be trained with our TAO toolkit.
NanoOWL is a Vision Transformer (ViT) model which is optimized from an opensource model on huggingface.
In short, PeopleNet uses the predefined labels but NanoOWL’s output is runtime generated.
So for my case I should use the PeopleNet, right?
@tiagoveracruzcm ,
Thanks for reaching out.
PeopleNet is a model that is specialized in detecting people. If you need to detect people only, it is likely the better choice.
NanoOWL is an “Open-Vocabulary” object detection model, that detects objects based on generic prompts like (“a chair”, “a dog”, “a hat”, etc.). This may be a good starting point if you don’t have a model for your specialized task, or have multiple classes of interest.
Hope this helps.
Best,
John
Thank you for your help.
I will use PeopleNet for people detection.
I still have 2 more questions:
  • Does run in Jetson Orin Nano? For a flight of 30 minutes and sending the images for a outside user…
  • Could I use the NanoOwl for infrastructure inspection? Can detect flaws or it isn’t prepared for that?
