Nisight 10.0 launch failed
I just updated to CUDA 10.0 and the toolkits.
And I can’t launch the Nsight(version = 10.0), there is a error message in the .metadata/.log.
!ENTRY org.eclipse.osgi 4 0 2018-11-19 12:36:30.450
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/w3c/dom/stylesheets/StyleSheet
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngineManager.getCSSSWTEngine(ThemeEngineManager.java:41)
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngineManager.getEngineForDisplay(ThemeEngineManager.java:30)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createThemeEngine(PartRenderingEngine.java:1428)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.initializeStyling(PartRenderingEngine.java:1281)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1036)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Caused by: java.lang.ClassNotFoundException: org.w3c.dom.stylesheets.StyleSheet cannot be found by org.eclipse.e4.ui.css.core_0.10.100.v20140424-2042
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:432)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499)
… 26 more
When I google this error message, they said eclipse 4.4 can’t work with Java 9.0. and 10.0
My environment is
Java 10.0
CUDA 10.0
Ubuntu 18.04
Thanks in advance.
nsight -vm /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java,not jdk 10
