(damn spelling correctors)
I just installed the cuda dev kit on a macbook pro. When I tried to launch nsight, it first complained that I did not have java 6 JRE installed, so I installed it. (I have Java 8 installed as well). Next time I tried to launch it quickly crashes with a dialog stating that an error has occurred and that I should check out a log file in ~/.eclipse/org.eclipse.platform_3.7.0_351938814/configuration/…
The log file contains:
!SESSION 2014-03-31 10:33:39.740 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_65
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -keyring /Users/Dave/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -keyring /Users/Dave/.eclipse_keyring -showlocation
!ENTRY org.eclipse.osgi 4 0 2014-03-31 10:33:40.066
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Any ideas?
Dave
