As the title says I cannot add a new viewport, the button is not available in my window menu - see snip below.
There are already two viewports available but I did not add them - I still want more.
The pipeline I have used up to this point is:
Create a scene in UE5.0 (windows 10)
Export as a USD (windows 10)
Make a few modifications to the scene with Create (windows 10)
Export the project as a .zip (windows 10)
Import the extracted project into Nucleus (Ubuntu 22)
Open Isaac and try to create a viewport (Ubuntu 22, Isaac 2022.2.0)
According to your docs there should be a “new viewport” button below the Extensions. As far as I can teel these docs are for the same version I am using.
Can someone help me find where the button is/why it is not there/any work around?
However, if you want to get back the “New Viewport Window” button you can always play (at your own risk :)) with the available code and make the following modifications in the exts/omni.isaac.app.setup/omni/isaac/app/setup/extension.py file:
