No boot after installing NVIDIA driver Ubuntu 20.04
Hi everyone,
I am using Ubuntu 20.04 with kernel “6.3.13-1-liquorix-amd64”. My pc has a RTX 4060 laptop.
If I install NVIDIA driver then Ubuntu freezes while booting, I have tried different version of driver but still same behaviour.
I am using liquorix version of kernel because the default version does not see my SSD and wifi so I am not able to use it. My pc is an Inspiron 16 plus 7630 → Processor: 13th gen Intel(R) Core™ i7-13620H and SSD: NVMe PM9B1 NVMe Samsung 1024Gb.
I need Ubuntu 20.04 because of ROS noetic
When does it freeze? And by freezing do you mean the black screen thing?
Can you see the grub menu?
I can see the grub menù, if I start ubuntu while booting it remains in black screen and never boot
Can you try this?
Go to advance options → recovery mode
Go to root and try this
sudo update-initramfs -u
Edit:
I realised that since it is root, sudo has no meaning.
Your internal display is driven by the intel igpu which needs a recent kernel and firmware. It seems liquorix has dropped support for 20.04 so you can only hope kernel 6.3 is new enough. Please download and install the firmware package:
http://mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_20220329.git681281e4-0ubuntu3.26_all.deb
Meanwhile, you should check if you can connect a monitor to the hdmi/dp port, this is like driven by the nvidia gpu and then would show the desktop.
Thanks to all
hdmi port does not work. I have installed the packaged and it seems that there are some progress, ubuntu starts but then I end up in a black screen with a flashing underscore
If I run using “nomodeset” option it starts but there is no output/input audio devices.
Update: I have install another version on NVIDIA drivers and now it works. Still no audio
Like the error message tells, the audio firmware is missing.
http://mirrors.kernel.org/ubuntu/pool/restricted/f/firmware-sof/firmware-sof-signed_2.0-1ubuntu4.5_all.deb
It’s just a plain bad idea to install ubuntu 20.04 on a notebook with new hardware.
Everything is working perfectly now. Thanks a lot!!
I know that is a bad idea but unfortunately ROS noetic is available only on Ubuntu 20.04
