What is this nonsense with extremely high CPU / GPU usage when the scene is completely empty?
There is nothing to render at all and yet my laptop is loud and getting hot for no reason.
I am not rendering, simulating or otherwise doing anything that would justify any CPU / GPU use at all, let alone having it high that I would need ear plugs to tolerate that.
When the scene / render is completely empty or blank I see a lot of CPU / GPU consumptions, even when I haven’t press ‘Play button’ on the left hand side.
Besides, I don’t need to have 60, or 120, FPS because I can reasonably get away with 25 FPS to just have a good view what is going on in the simulation. Everything above that is placebo FPS and not needed, especially if the on the flip side the cost could be ‘frying’ CPU, GPU and over heating internal SSD when not achieving or doing anything - idling.
@b.zarzycki1 the settings are only persistent if you edit apps/omni.isaac.sim.base.kit
or even with changing the settings here you see them reset when you restart isaac sim?
We are working on a better solution for the next release that decreases perf when not playing so when isaac sim is sitting idle, resource usage is low.
If someone is looking for where apps/omni.isaac.sim.base.kit can be found in Linux:
Go to Library-> Isaac Sim → Launch → Burger Button-> Settings and then you will find where Isaac Sim is installed and the file is located there.
