I am not able to log into Drive Xavier anymore. After I turned it off last time and turned it on today, the default password for the nvidia account does not work anymore. If I try to log in for a Guest session, I just see the blank green-black default screen and nothing else happens.
By default GDM (GNOME Display Manager) is configured to auto login with “nvidia” user.
Have you changed anything on your system? Can you login remotely through ssh?
I did not change anything on the system since I used it the last time.
It is not possible to start a terminal on the drive using ctrl+alt+f1/2/3/…, the screen just turns off when I try that.
If I check the IP by connecting another laptop to the ethernet and try to connect to the IP using nvidia@ip on the host machine I get the error “ssh: connect to host 10.85… port 22: Connection refused”.
If you can’t connect to DriveAGX via ssh, could you please try to connect DriveAGX with minicom tool like below?
If yes, I guess you will get the DriveAGX IP address.
When I connect via ssh and run the “sudo dpkg --configure -a” command I am still not able to log in. Also after a reboot I get to the same login screen and my password is not accepted.
Could you install the latest release (DRIVE Software 10.0) via SDK Manager on ubuntu 18.04? If any installation issue, please create a separate topic for it. Thanks!
