I have developed a custom deepstream application that runs manually from console as expected.
But when I tried creating a new systemd service to make it run on system startup, it fails to run.
I get following error
0:00:05.700770840 #033[332m10873#033[00m 0x55895dbb20 #033[33;01mWARN #033[00m #033[00m nvinfer gstnvinfer.cpp:2288:gst_nvinfer_output_loop:#033[00m error: Internal data stream error.
0:00:05.701985392 #033[332m10873#033[00m 0x55895dbb20 #033[33;01mWARN #033[00m #033[00m nvinfer gstnvinfer.cpp:2288:gst_nvinfer_output_loop:#033[00m error: streaming stopped, reason error (-5)
ERROR from element primary-nvinference-engine: Internal data stream error.
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(2288): gst_nvinfer_output_loop (): /GstPipeline:dstest3-pipeline/GstNvInfer:primary-nvinference-engine:
Deleting pipeline
• DeepStream Version
• TensorRT Version
• The pipeline being used
To reproduce - try to run deepstream sample app 3 as a service using the service script that was shared with this message
This is for production firmware on Jetson xavier nx to start auto loading the required deepstream based application, if necessary we may need to connect the xavier nx to monitor thats the reason OSD was not removed from pipeline
Pipeline is exactly similar to deepstream sample app 3 except for addition of videorate converter directly to sources to modify required FPS
With all this, application works as expected from shell when manually invoked but not as a service. We tried stopping and re-starting the service after complete OS startup, still it doesn’t work and fails exactly at inference module (logs highlight this)
Any update on this issue.
I even tried removing OSD from pipeline, this also dosnt work and stops the same way.
One more observation to share, like its able to infer 1 or 2 batches and only after that error pops out from inference engine.
Hi @aurointelli
Besides OSD, do you need render to display TV? I saw the app runs with multi-user.target , I guess rendering to display TV is not necessary, right?
If you remove tiler, you need to add demux into the pipeline.
you can add it tiler back, add enable GST_DEBUG=5 to get more debug log.
nvstreammux → nvinfer → nvdslogger → nvtiler → nvvidconv → nvosd → fakesink
nvstreammux → nvinfer → nvdslogger → nvtiler → nvvidconv → fakesink
besides, in your past test, how about the error you get for the case which reomove the OSD? same as the error in description?
With this I am not able to see additional logs (but with nvdslogger added without OSD, I can see additional logs as the pipeline is running - just to confirm that nvdslogger was added to pipeline)
As mentioned in the start of this thread (logs listed), with OSD enabled, pipeline stops with error code -5
