Just updated to today’s 331.65 WHQL driver and the GPU “info” pages under Nsight>Windows>System Info no longer work. I’m on Win7/x64 with VS2010 and Nsight 3.2.0.13289.
Refreshing the “GPU Devices” or “CUDA Devices” tab results in a rapid connect and disconnect from the Nsight Monitor and no results are shown:
We’ll look into it. May I suggest trying to pull the oldest cards out of your workstation one at a time? While all those cards should be supported, there’s a possibility something was broken with the driver update.
I reinstalled the drivers with no effect but have some more info:
Exporting the System Info results in a text file with proper looking NvAPI and NvDebugAPI sections (all 5 GPUs are listed) but then the file abruptly ends with:
CUDA
OpenCL
Unable to get platform count Information not available
All precompiled 64-bit CUDA Samples fail whether they’re driver or runtime versions: External Media
All precompiled 32-bit CUDA Samples succeed: External Media
We are able to reproduce this and are investigating what happened as a high priority. At this moment, I’d recommend you downgrading to the previous driver you were using, sorry not the best solution but it will get you going again for now.
Thanks for the report.
So what was the resolution on this one? I am experiencing absolutely the same issue after upgrading both my driver and nsight yesterday… Current versions:
