Nsight Eclipse: Failed to connect sshd on <remote-ip>
Hi all,
I am trying to use Nsight for remote application development (https://devblogs.nvidia.com/parallelforall/remote-application-development-nvidia-nsight-eclipse-edition/). I have the following setup:
  • Host: Ubuntu 14.04 64-bit (architecture: x86_64)
  • Target: Jetson TX1 board with 64-bit Ubuntu 16.04 (architecture: aarch64)
  • The host (IP: 192.168.1.9) and the target (IP: 192.168.1.14) are connected to the same wireless network
I’m following the instructions in the blog post above, but get stuck while adding a remote connection on the host. I go to my project properties and under Build -> Target Systems, select ‘Manage’. I add details for my Target system as shown below:
https://drive.google.com/file/d/0Bzt5qP5DPRxDNkpvT2lLS3RicHc/view?usp=sharing
Then when I click on ‘Browse’ for the Target project path, I get the following error:
https://drive.google.com/file/d/0Bzt5qP5DPRxDblBTUC1oRkI3QVE/view?usp=sharing
I am able to ssh to the Target through a terminal as follows:
https://drive.google.com/file/d/0Bzt5qP5DPRxDZDh5c0hxNDR5Tmc/view?usp=sharing
I’ve looked at similar problems online and tried their suggestions, but haven’t been able to resolve it.
https://devtalk.nvidia.com/default/topic/839207/eclipse-nsigh-on-mac-cannot-connect-via-ssh-tunnel-solved-/
https://devtalk.nvidia.com/default/topic/792228/cuda-setup-and-installation/nvvp-connect-to-remote-server-through-an-ssh-proxy/
https://medium.com/@rajeshkumar/executing-cuda-c-application-on-a-remote-machine-using-nsight-eclipse-fb8364029625#.3pcl1v2ct
Any help would be appreciated, thank you.
Since this question pertains to software development for the TX1 (via cross-compilation?) you may get better / faster help in the subforum dedicated to TX1: https://devtalk.nvidia.com/default/board/164/jetson-tx1/ . It seems to be quite active.
Hi njuffa,
Thanks for pointing that out. I’ll post it in that subforum.
