After installation both cache and nucleus server from omniverse launcher (following the current instruction), I am facing the issue that I can’t reach localhost. In the launcher I see:
During the installation the firewall and VPN were inactive. The system is Ubuntu 20.04 and I installed the newest versions of each software.
Interestingly enough, when I open Isaac Sim and log into the Nucleus Server in my organization, then everything is working as intended, but localhost still remain unreachable.
After the installation I used Cleanup Tool and install it again, but didn’t help.
Can you please validate all the services, especially auth and discovery, are running on your localhost?
You get to this from the hamburger menu->settings.
Launching an omniverse launcher from the terminal results in no logs, however I have something in ~/.nvidia-omniverse/logs. The content of this folder is in the attachment: logs.zip (289.4 KB)
If you’re hitting this error, it’s likely your port is blocked somehow.
You’ll need to try and open the ports Nucleus needs.
It’s also possible Nucleus didn’t install correctly.
You can try uninstalling, then reinstalling and rebooting to see if that works as well.
