Hi, I’m trying to setup isaac from scratch using the omniverse system. When I first launch the application I get an error because numpy==1.21.2 cannot be used with numba==0.54.0. When run Isaac shows
2021-08-25 08:37:48 [7,426ms] [Error] [carb.python] [py stderr]: RuntimeError
2021-08-25 08:37:48 [7,426ms] [Error] [carb.python] [py stderr]: :
2021-08-25 08:37:48 [7,426ms] [Error] [carb.python] [py stderr]: module compiled against API version 0xe but this version of numpy is 0xd
This can be “solved” by manually installing numpy==1.20.3 via python.sh -m pip install. IDK if it’s just me but I’ve tried this on a fresh system.
Moreover, while installing the requirements I get the following
ERROR: aiobotocore 1.2.0 has requirement botocore<1.19.53,>=1.19.52, but you'll have botocore 1.19.53 which is incompatible.
ERROR: tensorflow-gpu 2.3.1 has requirement numpy<1.19.0,>=1.16.0, but you'll have numpy 1.20.3 which is incompatible.
