I then reinstalled the CUDA driver above and it said it finished succesfully and also ran the nvidia-xconfig to update the xorg.conf which i verified.
I rebooted but Xserver fails to launch. I get a blank screen. I switched to a console terminal to check /var/log/Xorg.0.log and it has the following error messages in the end:
Nevermind! Got resolved. I reinstalled linux-restricted-modules using apt-get and it worked. I ran the sample CUDA app deviceQuery and it said found 8600GT (to my surprise! :) …i thought I had an 8400.). Does this test confirm that my cuda device/driver is sucessfully installed and ready to run my apps?
Watch out for linux-restricted-modules. You might lose the new driver on the next reboot. I tend to uninstall anything related to NVIDIA kernel drivers and only install the downloaded driver, on Ubuntu.
If you’re good after the next reboot, then you’re good.
Now pay attention to the upgrades, and rerun NVIDIA-Linux-*.run whenever there is a new kernel.
(A more elaborate script in rc.local could detect this and automatically compile the module as needed.)
This might not be the most elegant solution, but seems to be very robust and avoid destroying the Ubuntu package dependencies, or waiting for tools such as Envy to be upgraded with the latest (beta?) drivers.
Just a note for others trying to get this stuff working…
I’m on
Dell Latitude D630 with an Quadro NVS 135M that’s got 256 megs of ram
Ubuntu Hardy (8.04) 64-bit
I uninstalled all nvidia related packages and then ran the install script that compiled its own kernel driver and installed the GL drivers. Initially I had problems with version mis-matches, so if you have had any nvidia drivers previously installed you might want to clean out your /lib/modules of old nvidia.ko files.
So, with the latest drivers I can compile both the Cuda 1.1 and the Cuda2 beta releases. 1.1 required installing gcc and g++ 4.1 as well as changing the symlinks in /usr/bin to point to them, while the beta2 did not.
I can compile most things and I can run the device query app. Beyond that, virtually nothing really works. The nbody and particle simulations come up, but no matter how I adjust the sliders they just blink non stop. If I step the animation by hitting return then they both just switch back and forth between two different states, which look like the initial configuration and some totally spazzed out state. Most of the demos I get a memory error, a segmentation fault or it will crash X or my whole machine.
I once had the simpleGL app running correctly, but after having tried one or two other failed demos it has gone back to the single red dot in the middle of the window that doesn’t move. That’s all I get for it now.
I’ve tried adjusting some of the parameters for demos like the oceanFFT to see if I could cut it down smaller to deal with what seems to be an out of memory error. (256megs seems sufficient for a little surface animation, but…???) No luck. Still get this error:
*** glibc detected *** ./fluidsGL: double free or corruption (out): 0x0000000000683490 ***
I feel your pain! Every time I tried them I had problems with the installers from NVidia. I’m not sure that’s the reason for your issues, but I just thought I’d point you to this guide, it works well for me. Hope it helps!
