My camera is connected through GMSL port, but I would like to know from where is this device taken SF3324-CSI-A, because I would like to use it in my project, so I need path to the device.
I would suggest you start with SIPL (Sensor Input Processing Library) Camera and its source code is under ~/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux/samples/nvmedia/nvsipl/test/camera of your host system (after installing DRIVE Software 10.0 with SDK Manager).
so I find out that it must be /dev//dev/capture-vi-channel0 and/or /dev//dev/capture-isp-channel0, correct me if I am wrong.
I tried to use it in my program but still I was not able to get camera input :/
Here I found sentence “The NvMedia camera applications use an Ethernet-based Control Communication protocol to request camera power on/off at the AURIX processors. It is not necessary to manually turn the camera power on/off through the AURIX shell interface.” so I assume that I need power on camera manually before using it.
