Would like to know if the NVIDIA NVS 810 Graphics card compatible with Windows 11?
If it is not is there recommended replacement. I need to run two of these cards to display on 14 monitors.
Thank you for your time.
Hello @lopezjljk2, welcome to the NVIDIA developer forums.
As mentioned in the thread where you originally replied, it is unlikely that this setup will still work on the latest Windows 11 versions because of incompatible changes in WDDM and the older GPU drivers. The last official driver for the NVS 810 is
Driver Version: R470 U18 (475.14) Release Date: Tue Jul 09, 2024
NVIDIA does not currently offer a GPU with the same amount of display connections. For 14 Displays you would need 4 NVIDIA GPUs.
