NVIDIA SDK Manager JetPack 6.0 Conform Version Not Found
Hi,I try use Nvidia SDK Manager Download
JetPack 6.0 to Reinstall DeepStream
and other JetPack Components,
But only look 6.0 rev.2 version,
No see conform to My Factory Jeson info version.
How Can I Reinstall My JetPack Components?
Hi Alpha.Chen,
If you are using the devkit, could you try using the latest JP6.1(R36.4.0).
You can also run the following command to install SDK components manually.
$ sudo apt install nvidia-jetpack
I use custom board,
Theese command also work?
Yes, that is the command to install SDK components and it should also work on your custom carrier board.
ok,thanks!!!
