Hello
We have succeeded in ORIN NX SSD CLONE through NVME SSD CLONE equipment.
equipment:
Then I take out the module and try to check it, but it doesn’t boot.
Can you tell me what’s the problem?
Hello
equipment:
so the SSD is inserted into a brand new module? That way, please first flash the bootloader stuff into the device, or it will not boot up even though the SSD is working, just like in your case
sudo ./flash.sh -c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
--no-systemimg jetson-orin-nano-devkit nvme0n1p1
In case you are using the Xavier NX DevKit as the carrier board
--no-systemimg p3509-a02+p3767-0000 nvme0n1p1
Hi @DaveYYY
I used the new module as you said, and used the inform command, but the following error message came out
Please put the full log here.
Here is log
result.txt (77.3 KB)
Thanks, then can you please try again with this?
sudo ./tools/kernel_flash/l4t_initrd_flash.sh -p "--no-systemimg -c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
--network usb0 p3509-a02+p3767-0000 nvme0n1p1
Thank you @DaveYYY it is work
