Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”): Software Version
DRIVE OS Linux 5.1.6.1
other DRIVE OS version
other
I made a script that reads the frame count registers for all VI channels (see below).
I am expecting to get some count greater than zero when I run the script while I’m running nvmimg_cc with a working setup (SEKO camera, captured image is displayed on the screen).
But all registers are returning zeros (0x00000000) !?
Please try to read Pixel Width of frame register and FRAME_COUNT register of channel 35 (0x15F19C34 and 0x15F19C70 respectively) and see if any non zero values.
0x15F19C70
While nvmimg_cc is running, 0x15F19C7 almost always reads 0x00000000, very rarely I see 0x00001000
With nvmimg_cc stopped, 0x15F19C7 always reads 0x00002001
This is not what I expect. I expect the corresponding channel frame_count register to count up and see an increasing number for Frame Start and Frame End in the register. The counters in the register are 12 bit wide so they can count frames for 136 seconds (at 30fps) before they saturate.
What does value in register 0x15F19C34 indicate?
Why do you ask me to read channel 35 (only)?
The Note you pointed to says: “The vi_channel_no starts from 35 downwards for RGB, RAW, and YUV packed formats, and from 0 upwards for YUV planar and semiplanar formats.”
If I understand the note correctly, vi channel 35 would be for RGB. But the nvmimg_cc application uses RAW12 !?
Any ideas how I can get the debugging (registers) going?
I confirmed that the debug method mentioned in VI Frame Count section doesn’t work because the registers get clear for other functions.
Please try with the method of CSI Debug Counters section. Thanks.
And then at the end of the page the VI channel register are mentioned.
But only addresses for VC0-registers are given:
0x15f1101c
0x15f11028
0x15f11030
0x15f11034
0x15f11038
Can you please forward the addresses of the VI channel registers for VC1 to VC15.
Please refer to CSI Debug Counters and the following example to read the counts.
program registers
#program debug control 0 to read VC0 EOF events on stream 0
devmem2 0x15a00084 w 0x701 #program debug control 1 to read VC0 SOF events on stream 0
devmem2 0x15a00088 w 0x801 #clear debuf counter 0
devmem2 0x15a0009c w 0x1 #clear debug counter 1
devmem2 0x15a000a0 w 0x1
read EOF/SOF count
devmem2 0x15a0009c; devmem2 0x15a000a0
/dev/mem opened.
Memory mapped at address 0x7f88aea000.
Value at address 0x15A0009C (0x7f88aea09c): 0x0000003F
/dev/mem opened.
Memory mapped at address 0x7fb5e33000.
Value at address 0x15A000A0 (0x7fb5e330a0): 0x0000003F
I have done exactly what you described and all counters for SOF/EOF are reading zero all the time.
They read zero while the camera capture is running and they read zero after stopping the capture.
So nvmimg_cc seems to not use VC0, is that correct? Which VC does nvmimg_cc use?
The question in my last post was regarding the VI Channel registers, not the CSI Debug Counters.
Register addresses are only given for VI channel 0. Can you please provide the register addresses of the other VI channels. And alos some information on which VI channels are used.
