OmniIsaacGymEnvs problem
I installed the Isaac Sim environment inside Anaconda, but encountered the following issue while executing 9.1. Overview & Getting Started.
  1. First, I ran git clone https://github.com/NVIDIA-Omniverse/OmniIsaacGymEnvs.git to install the files into the Isaac Sim 2023.1.1 version folder.
  2. I set the path to the folder containing setup.py, which is OmniIsaacGymEnvs.
  3. I ran pip install -e ..
  4. It showed that the installation was successful.
  5. I opened VSCode in the Anaconda Isaac Sim environment and executed the example file scripts/random_policy.py, but encountered the following issue:
I found that gym, hydra, and other packages installed via setup.py cannot be found in VSCode. I’m wondering where the problem might be?
Below is where I installed the plugin
Hi @nick222446 - Have you followed the Isaac Sim installation properly mentioned in the doc here?
https://docs.omniverse.nvidia.com/isaacsim/latest/isaac_gym_tutorials/tutorial_gym_isaac_gym.html#getting-started
Yes, I have tried the method provided in that URL.
I used the installation method for Windows, but it doesen’t work.
I confirmed with Dev and she told me to avoid using conda for OIGE. it could be it’s picking up a different python environment in vscode
I tried to execute the instructions from the official website in the original VSCode environment, but it seems that setting the PYTHON_PATH environment variable in the Windows terminal doesn’t work. Could you provide the URL for the official installation video tutorial for OmniIsaacGymEnvs?
Hi @nick222446 - Instructions are provided in the above doc link that I provided. Attaching it again:
