I’ve successfully installed Omniverse Code 2022.1.2 on another similar Windows AMD FX-8320 box that does not have an RTX card but has a near-identical OS and tool installation. However, the machine I actually want to use it on (which has an AMD Ryzen 9 5950X and an RTX3070) won’t complete the installation. It hangs when installing the EXTSCACHE/OMNI.CURVE.NODES without explanation or progress for (going on) half a day now.
There appears to be no way to back out of the installation either. It’s still stuck there after a reboot and a restart of Omniverse. There’s no apparent means to uninstall it or otherwise abort or restart the installation.
Any ideas welcome!
Hi @alex133. Welcome to the forums! Sorry you’re having trouble.
Have you tried the Cleanup Tool yet? Could you give the installation one more try after running the Cleanup Tool? Cleanup-Tool — Omniverse Launcher documentation
If that fails, could you share your log files with us? More info about how to grab those here: How to Report an issue with Omniverse
I was under the impression that the cleanup tool is not selective - as in it won’t target “Code” specifically, but removes all installed applications in the Omniverse engine. But if that is the only way forward…
Incidentally, where do I find these logs? The “hang” in itself is not giving any clues.
No, that’s fine. You can skip the cleanup. Because you’re new to the forums, I thought maybe Code was your first app.
The second link I provided has all the info about where to find the logs.
Hopefully this’ll work :)
Onedrive log share
Thank you @alex133. I didn’t see any Launcher logs in there. They’d be at the root of the logs dir in:
C:\Users\<USERNAME>\.nvidia-omniverse\logs
Best thing would be to just zip up that folder to not miss anything.
Ok - I’ve added them to the same folder - just reuse the link
It didn’t like me zipping because all sorts were “in use”. :)
Ok - everything shut down and ZIP now successful - see the same link.
Thank you! I’ve sent this along to the dev team.
Hi @alex133. Sorry for the delay. We’ve opened OM-61133 to track this. Are you still stuck?
