I ordered The Orin AGX 64gb Developer kit from amazon in the United Kingdom, It was shipped with three power cables, none of which work in the UK.
It appears that you have received the Orin AGX 64gb Developer kit from Amazon in the United Kingdom, but the power cables provided are not compatible with UK power outlets.
The Orin AGX Developer kit is a product from NVIDIA, a technology company that specializes in designing and manufacturing graphics processing units (GPUs) and high-performance computing hardware.
To resolve this issue, you may want to consider the following options:
- Contact NVIDIA Support: Reach out to NVIDIA’s customer support team to report the issue and request replacement power cables that are compatible with UK power outlets. They may be able to provide you with a solution or guide you on how to obtain the correct cables.
- Contact Amazon UK: As the seller, Amazon UK may be able to assist you in resolving the issue. You can contact their customer service team to report the problem and ask for their help in obtaining the correct power cables.
- Purchase a UK-compatible power cable: If the above options do not yield a solution, you can consider purchasing a UK-compatible power cable separately. Ensure that the cable is compatible with the Orin AGX Developer kit’s power requirements.
In terms of product SKUs, it is possible that the Orin AGX 64gb Developer kit is available in different regions with varying power cable configurations. However, without further information on the product SKU, it is difficult to provide a more specific solution.
In comparison to other NVIDIA products, the Orin AGX Developer kit is a specialized platform designed for developers, whereas other products like the NVIDIA Jetson series may have different power cable configurations.
To enable performance logging, debug, or other settings, you may need to refer to the Orin AGX Developer kit’s documentation or contact NVIDIA support for guidance.
Lastly, the mention of “tempImageEEauJi 3024×4032 2.2 MB” appears to be a file name and dimensions, which may be related to an image or screenshot you took of the issue. If you need help with sharing or uploading this image, please let me know.
Please help to provide the purchase link, thanks
here is the link :
Jetson Orin AGX
By checking the link, that seems some error at Amazon as disti needs to fix.
The part number on that page is: 945-13730-0050-000
Per Jetson FAQ | NVIDIA Developer, that is not UK PN.
It even shows on the page that UK power cable not included
I have informed intenal team to contact our PIC for Amazon to fix it.
Do you know where Can I buy the UK power cable for this?
