Orin boot fail with 4K monitor
Hi NVIDIA team
I have a problem,that Orin boot fail with 4K support monitor
but with 1080p only monitor,work fine.
Boot success with 1080p monitor then change to 4K monitor that is OK
DeBug UART message as follows
[0000.066] I> MB1 (version: 0.11.0.0-t234-54845784-7fb1fa27)
[0000.071] I> t234-A01-0-Silicon (0x12347) Prod
[0000.075] I> Boot-mode : Coldboot
[0000.078] I> Emulation:
[0000.081] I> Entry timestamp: 0x00000000
[0000.085] I> last_boot_error: 0x0
[0000.088] I> BR-BCT: preprod_dev_sign: 0
[0000.091] I> rst_source: 0x0, rst_level: 0x0
[0000.096] I> Task: Clocks enable (0x50011b9d)
[0000.100] I> Task: Crypto init (0x50018df5)
[0000.104] I> Task: Secure debug controls (0x5000c76d)
[0000.109] E> Error: ECID of check failed!!
[0000.113] E> Error: ECID of check failed!!
[0000.117] E> Error: ECID of check failed!!
[0000.121] E> Error: ECID of check failed!!
[0000.124] I> Task: Program NV master stream id (0x5000c725)
[0000.130] I> Task: Verify boot mode (0xd482021)
[0000.138] I> Task: Alias fuses (0x5000ecd5)
[0000.143] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.150] I> Task: 0x5000e911
[0000.153] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.158] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.162] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.167] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.171] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.175] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.179] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.183] I> FUSE_SKU_INFO_0 = 0xd0
[0000.187] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.191] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.194] I> SKU: Perfect F0
[0000.197] I> Task: Voltage monitor (0x50011ba5)
[0000.201] I> VMON: Vmon re-calibration and fine tuning done
[0000.207] I> Task: Blockdev init (0x500157e1)
[0000.211] I> Task: UPHY init (0x5001b42d)
[0000.215] E> UPHY: UPHY lane info table is empty in MB1 BCT.
[0000.221] I> Task: Boot device init (0x5000d6a9)
[0000.225] E> Adding eMMC storage modules
[0000.229] I> Boot-device: QSPI (instance: 0)
[0000.233] I> qspi flash params source = mb1bct
[0000.237] I> Qspi clock source : pllc_out0
[0000.242] I> QSPI-0l initialized successfully
[0000.246] I> Task: TSC init (0x5001c7e1)
[0000.250] I> Task: Enable WDT 5th expiry (0x5001d27d)
[0000.255] I> Task: Disable WDT globally (0x5001d2b9)
[0000.259] I> Task: I2C register (0x50000a09)
[0000.264] I> Task: Reset FSI (0x50011ba1)
[0000.267] I> Task: Pinmux init (0x50010e95)
[0000.272] I> Task: Prod config init (0x50011075)
[0000.276] I> Task: Pad voltage init (0x50010f85)
[0000.281] I> Task: Prod init (0x50011119)
[0000.285] I> Task: Thermal check (0x5001121d)
[0000.289] I> max_chip_limit = 115
[0000.292] I> min_chip_limit = -30
[0000.305] I> max temp read = 36
[0000.308] I> min temp read = 35
[0000.311] I> Task: Common rail init (0x50011695)
[0000.316] W> Thermal config not found in BCT
[0000.320] W> Generic i2c config not found in BCT
[0000.325] > DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.333] W> MEMIO rail config not found in BCT
[0000.337] I> Task: Mem clock src (0x5000f6b9)
[0000.341] I> Task: BR PMIC seq (0x50011711)
[0000.346] I> Task: Misc. board config (0x500116ed)
[0000.350] W> Platform config not found in BCT
[0000.354] I> Task: Load membct (0x5000f5d5)
[0000.358] I> RAM_CODE 0x4000401
[0000.362] I> Loading MEM-BCT to SysRAM
[0000.365] I> Scratch RSV109: 0x00000001 active chain: 0
[0000.370] I> Slot: 0
[0000.372] I> Binary[0] block-0 (partition size: 0x40000)
[0000.378] I> get_binary_info: Binary name: MEM-BCT-0
[0000.382] I> Size of crypto header is 8192
[0000.386] I> BCH load address is : 0x40050000
[0000.391] I> Size of crypto header is 8192
[0000.395] I> BCH of MEM-BCT-0 read from storage
[0000.399] I> BCH address is : 0x40050000
[0000.403] I> MEM-BCT-0 header integrity check is success
[0000.408] I> Binary magic in BCH component 0 is MEM0
[0000.413] I> component binary type is 0
[0000.417] I> MEM-BCT-0 binary is read from storage
[0000.422] I> MEM-BCT-0 binary integrity check is success
[0000.427] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.438] I> RAM_CODE 0x4000401
[0000.442] I> Task: Save mem-bct info (0x50011d59)
[0000.446] I> Task: SDRAM params override (0x50010c79)
[0000.451] I> Task: Carveout allocate (0x50011da5)
[0000.456] I> RCM blob carveout will not be allocated
[0000.460] I> ECC region[0]: Start:0x0, End:0x0
[0000.465] I> ECC region[1]: Start:0x0, End:0x0
[0000.469] I> ECC region[2]: Start:0x0, End:0x0
[0000.473] I> ECC region[3]: Start:0x0, End:0x0
[0000.477] I> ECC region[4]: Start:0x0, End:0x0
[0000.482] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.488] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.492] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.497] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.501] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.508] I> allocated(CO:51) base:0x80000000 size:0x8000000 align: 0x200000
[0000.515] I> allocated(CO:44) base:0xd6000000 size:0x2a000000 align: 0x100000
[0000.522] I> allocated(CO:31) base:0xce000000 size:0x8000000 align: 0x100000
[0000.529] I> allocated(CO:39) base:0xc8000000 size:0x6000000 align: 0x200000
[0000.536] I> allocated(CO:20) base:0xc6000000 size:0x2000000 align: 0x2000000
[0000.543] I> allocated(CO:24) base:0xc4000000 size:0x2000000 align: 0x2000000
[0000.550] I> allocated(CO:28) base:0xc2000000 size:0x2000000 align: 0x2000000
[0000.557] I> allocated(CO:29) base:0xc0000000 size:0x2000000 align: 0x2000000
[0000.564] I> allocated(CO:41) base:0xbf000000 size:0x1000000 align: 0x100000
[0000.571] I> allocated(CO:43) base:0xbe000000 size:0x1000000 align: 0x200000
[0000.578] I> allocated(CO:02) base:0xbd800000 size:0x800000 align: 0x800000
[0000.585] I> allocated(CO:03) base:0xbd000000 size:0x800000 align: 0x800000
[0000.592] I> allocated(CO:06) base:0xbc800000 size:0x800000 align: 0x800000
[0000.598] I> allocated(CO:10) base:0xbc000000 size:0x800000 align: 0x800000
[0000.605] I> allocated(CO:56) base:0xbb800000 size:0x800000 align: 0x200000
[0000.612] I> allocated(CO:07) base:0xbb400000 size:0x400000 align: 0x400000
[0000.619] I> allocated(CO:22) base:0xbb000000 size:0x400000 align: 0x400000
[0000.626] I> allocated(CO:33) base:0xbac00000 size:0x400000 align: 0x200000
[0000.633] I> allocated(CO:47) base:0xba800000 size:0x400000 align: 0x200000
[0000.639] I> allocated(CO:01) base:0xba700000 size:0x100000 align: 0x100000
[0000.646] I> allocated(CO:04) base:0xba600000 size:0x100000 align: 0x100000
[0000.653] I> allocated(CO:05) base:0xba500000 size:0x100000 align: 0x100000
[0000.660] I> allocated(CO:08) base:0xba400000 size:0x100000 align: 0x100000
[0000.667] I> allocated(CO:09) base:0xba300000 size:0x100000 align: 0x100000
[0000.674] I> allocated(CO:15) base:0xba200000 size:0x100000 align: 0x100000
[0000.680] I> allocated(CO:17) base:0xba100000 size:0x100000 align: 0x100000
[0000.687] I> allocated(CO:23) base:0xba000000 size:0x100000 align: 0x100000
[0000.694] I> allocated(CO:27) base:0xb9f00000 size:0x100000 align: 0x100000
[0000.701] I> allocated(CO:42) base:0xb9e00000 size:0x100000 align: 0x100000
[0000.708] I> allocated(CO:54) base:0xb9d80000 size:0x80000 align: 0x80000
[0000.714] I> allocated(CO:26) base:0xb9d40000 size:0x40000 align: 0x2000
[0000.721] I> allocated(CO:48) base:0xb9d20000 size:0x20000 align: 0x10000
[0000.728] I> allocated(CO:34) base:0xb9d10000 size:0x10000 align: 0x10000
[0000.734] I> allocated(CO:35) base:0xb9d00000 size:0x10000 align: 0x10000
[0000.741] I> allocated(CO:49) base:0xb9cf0000 size:0x10000 align: 0x10000
[0000.747] I> allocated(CO:50) base:0xb9ce0000 size:0x10000 align: 0x10000
[0000.754] I> allocated(CO:52) base:0xb9cd0000 size:0x10000 align: 0x10000
[0000.761] I> Task: SDRAM init (0x5000f6bd)
[0000.767] I> SDRAM-params @ 0xd485000
[0000.771] I> MSS code-drop: NvBootSdramInit
[0000.775] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0000.782] I> MSS CAR: Init PLLM
[0000.785] I> MSS CAR: Init PLLHUB
[0000.796] I> mb1_sdram_init Done !
[0000.799] I> SDRAM Size in Total 800000000
[0000.803] I> SDRAM test pass
[0000.806] I> Task: Dram ecc scrub (0x5000f2c9)
[0000.810] I> Task: DRAM alias check (0x50010c71)
[0001.026] I> Task: Register checker (0x50010c75)
[0001.035] I> Task: Enable clock-mon (0x5001c301)
[0001.052] I> FMON: Fmon re-programmed in mb1
[0001.056] I> Task: Mapper init (0x5001a0d5)
[0001.062] I> Task: SC7 Context Init (0x5001cacd)
[0001.068] I> NV_SC7 Context addr: 0xa0000000
[0001.073] I> Task: CCPLEX IST init (0x5000ce75)
[0001.079] I> Task: CPU WP0 (0x5000c2c9)
[0001.084] I> Loading MCE
[0001.087] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.093] I> Slot: 0
[0001.095] I> Binary[8] block-0 (partition size: 0x80000)
[0001.101] I> get_binary_info: Binary name: MCE
[0001.106] I> Size of crypto header is 8192
[0001.111] I> BCH load address is : 0x4003e000
[0001.116] I> Size of crypto header is 8192
[0001.121] I> BCH of MCE read from storage
[0001.125] I> BCH address is : 0x4003e000
[0001.131] I> MCE header integrity check is success
[0001.136] I> Binary magic in BCH component 0 is MTSM
[0001.141] I> component binary type is 8
[0001.145] I> Size of crypto header is 8192
[0001.152] I> MCE binary is read from storage
[0001.157] I> MCE binary integrity check is success
[0001.162] I> Binary MCE loaded successfully at 0x40000000 (0x29e90)
[0001.170] I> Size of crypto header is 8192
[0001.181] I> Size of crypto header is 8192
[0001.186] I> Sending WP0 mailbox command to PSC
[0001.199] I> Task: MB1 fixed firewalls (0x5001b1bd)
[0001.210] I> Task: Load bpmp-fw (0x5001b311)
[0001.216] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.222] I> Slot: 0
[0001.224] I> Binary[15] block-0 (partition size: 0x100000)
[0001.230] I> get_binary_info: Binary name: BPMP_FW
[0001.236] I> Size of crypto header is 8192
[0001.240] I> BCH load address is : 0x807fe000
[0001.246] I> Size of crypto header is 8192
[0001.250] I> BCH of BPMP_FW read from storage
[0001.255] I> BCH address is : 0x807fe000
[0001.261] I> BPMP_FW header integrity check is success
[0001.266] I> Binary magic in BCH component 0 is BPMF
[0001.271] I> component binary type is 15
[0001.276] I> Size of crypto header is 8192
[0001.291] I> BPMP_FW binary is read from storage
[0001.298] I> BPMP_FW binary integrity check is success
[0001.303] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf3940)
[0001.311] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.317] I> Slot: 0
[0001.320] I> Binary[16] block-0 (partition size: 0x100000)
[0001.326] I> get_binary_info: Binary name: BPMP_FW_DTB
[0001.332] I> Size of crypto header is 8192
[0001.336] I> BCH load address is : 0x807fc000
[0001.342] I> Size of crypto header is 8192
[0001.346] I> BCH of BPMP_FW_DTB read from storage
[0001.351] I> BCH address is : 0x807fc000
[0001.357] I> BPMP_FW_DTB header integrity check is success
[0001.363] I> Binary magic in BCH component 0 is BPMD
[0001.368] I> component binary type is 16
[0001.372] I> Size of crypto header is 8192
[0001.379] I> BPMP_FW_DTB binary is read from storage
[0001.385] I> BPMP_FW_DTB binary integrity check is success
[0001.390] I> Binary BPMP_FW_DTB loaded successfully at 0x807dbc00 (0x20380)
[0001.399] I> Program IPC carveouts
[0001.405] I> Task: Load psc-fw (0x5001b3b9)
[0001.410] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.416] I> Slot: 0
[0001.418] I> Binary[17] block-0 (partition size: 0x80000)
[0001.425] I> get_binary_info: Binary name: PSC_FW
[0001.430] I> Size of crypto header is 8192
[0001.434] I> BCH load address is : 0x803fe000
[0001.440] I> Size of crypto header is 8192
[0001.445] I> BCH of PSC_FW read from storage
[0001.449] I> BCH address is : 0x803fe000
[0001.455] I> PSC_FW header integrity check is success
[0001.460] I> Binary magic in BCH component 0 is PFWP
[0001.465] I> component binary type is 17
[0001.470] I> Size of crypto header is 8192
[0001.478] I> PSC_FW binary is read from storage
[0001.484] I> PSC_FW binary integrity check is success
[0001.489] I> Binary PSC_FW loaded successfully at 0x80000000 (0x57800)
[0001.498] I> Task: Load nvdec-fw (0x5001c05d)
[0001.503] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.509] I> Slot: 0
[0001.512] I> Binary[7] block-0 (partition size: 0x100000)
[0001.518] I> get_binary_info: Binary name: NVDEC
[0001.523] I> Size of crypto header is 8192
[0001.527] I> BCH load address is : 0x800fe000
[0001.533] I> Size of crypto header is 8192
[0001.538] I> BCH of NVDEC read from storage
[0001.542] I> BCH address is : 0x800fe000
[0001.548] I> NVDEC header integrity check is success
[0001.553] I> Binary magic in BCH component 0 is NDEC
[0001.558] I> component binary type is 7
[0001.562] I> Size of crypto header is 8192
[0001.569] I> NVDEC binary is read from storage
[0001.575] I> NVDEC binary integrity check is success
[0001.580] I> Binary NVDEC loaded successfully at 0x80000000 (0x35000)
[0001.593] I> Task: Load tsec-fw (0x5001c249)
[0001.598] I> TSEC-FW load support not enabled
[0001.602] I> Task: TZDRAM setup (0x50012515)
[0001.608] I> Task: SC7 context save (0x5001cbd1)
[0001.614] I> NV_SC7 Context addr: 0xa0000000
[0001.620] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.626] I> Slot: 0
[0001.628] I> Binary[13] block-0 (partition size: 0x20000)
[0001.634] I> get_binary_info: Binary name: SC7-FW
[0001.639] I> Size of crypto header is 8192
[0001.644] I> Size of crypto header is 8192
[0001.648] I> BCH load address is : 0xa0002000
[0001.654] I> Size of crypto header is 8192
[0001.659] I> BCH of SC7-FW read from storage
[0001.663] I> BCH address is : 0xa0002000
[0001.669] I> SC7-FW header integrity check is success
[0001.674] I> Binary magic in BCH component 0 is WB0B
[0001.680] I> component binary type is 13
[0001.684] I> Size of crypto header is 8192
[0001.689] I> SC7-FW binary is read from storage
[0001.695] I> SC7-FW binary integrity check is success
[0001.700] I> Binary SC7-FW loaded successfully at 0xa0004000 (0xa4e0)
[0001.708] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.714] I> Slot: 0
[0001.716] I> Binary[22] block-0 (partition size: 0x30000)
[0001.722] I> get_binary_info: Binary name: PSC_RF
[0001.727] I> Size of crypto header is 8192
[0001.732] I> Size of crypto header is 8192
[0001.736] I> BCH load address is : 0xa000e4e0
[0001.742] I> Size of crypto header is 8192
[0001.747] I> BCH of PSC_RF read from storage
[0001.751] I> BCH address is : 0xa000e4e0
[0001.757] I> PSC_RF header integrity check is success
[0001.762] I> Binary magic in BCH component 0 is PSCR
[0001.768] I> component binary type is 22
[0001.772] I> Size of crypto header is 8192
[0001.778] I> PSC_RF binary is read from storage
[0001.783] I> PSC_RF binary integrity check is success
[0001.789] I> Binary PSC_RF loaded successfully at 0xa00104e0 (0x1af70)
[0001.808] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.814] I> Slot: 0
[0001.816] I> Binary[14] block-0 (partition size: 0x20000)
[0001.822] I> get_binary_info: Binary name: MB2_RF
[0001.827] I> Size of crypto header is 8192
[0001.832] I> Size of crypto header is 8192
[0001.836] I> BCH load address is : 0xa008c020
[0001.842] I> Size of crypto header is 8192
[0001.847] I> BCH of MB2_RF read from storage
[0001.851] I> BCH address is : 0xa008c020
[0001.857] I> MB2_RF header integrity check is success
[0001.862] I> Binary magic in BCH component 0 is MB2R
[0001.868] I> component binary type is 14
[0001.872] I> Size of crypto header is 8192
[0001.877] I> MB2_RF binary is read from storage
[0001.883] I> MB2_RF binary integrity check is success
[0001.888] I> Binary MB2_RF loaded successfully at 0xa008e020 (0xd360)
[0001.897] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0001.904] I> SC7 context fuse-bypass data is empty
[0001.910] I> SC7 context save done
[0001.913] I> Task: Load MB2/Applet/FSKP (0x5001c305)
[0001.919] I> Loading MB2
[0001.922] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.928] I> Slot: 0
[0001.931] I> Binary[6] block-0 (partition size: 0x70000)
[0001.937] I> get_binary_info: Binary name: MB2
[0001.941] I> Size of crypto header is 8192
[0001.946] I> BCH load address is : 0x8007e000
[0001.951] I> Size of crypto header is 8192
[0001.956] I> BCH of MB2 read from storage
[0001.961] I> BCH address is : 0x8007e000
[0001.966] I> MB2 header integrity check is success
[0001.971] I> Binary magic in BCH component 0 is MB2B
[0001.977] I> component binary type is 6
[0001.981] I> Size of crypto header is 8192
[0001.990] I> MB2 binary is read from storage
[0001.996] I> MB2 binary integrity check is success
[0002.001] I> Binary MB2 loaded successfully at 0x80000000 (0x69940)
[0002.009] I> Task: Prepare MB2 params (0x5001c3d5)
[0002.016] I> MB2-params @ 0x40060000
[0002.023] I> BR-BCT Boot Chain Fields
[0002.027] I> u32_non_gpio_select_boot_chain : 0
[0002.032] I> u32_num_boot_chains : 2
[0002.037] I> bf_bl_gpio_select_boot_chain_1b : 0
[0002.043] I> Task: Dram ecc test (0x5000f379)
[0002.048] I> Task: Misc NV security settings (0x5000ca35)
[0002.055] I> NVDEC sticky bits programming done
[0002.060] I> Task: GPIO interrupt map (0x50011a61)
[0002.066] I> Task: Disable/Reload WDT (0x5001d2e9)
[0002.072] I> Programmed SLCG global override := 0x0
[0002.077] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-e8d12f8b)
I> Emulation:
I> Entry timestamp: 0x0020673a
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0xbb800000, size:0x800000]
I> Task: Enable hot-plug capability (0x5001aed8)
I> Task: Set blob address (0x50001c70)
I> Task: PSC mailbox init (0x5000e5e0)
I> Task: Crypto init (0x50005abc)
I> Task: I2C register (0x50001c5c)
I> Task: Boot device init (0x50001d2c)
I> Boot_device: QSPI_FLASH instance: 0
I> qspi flash-0 params source = MB2 params
I> sdmmc-3 params source = MB2 params
I> Task: Partition Manager Init (0x50001cf8)
I> Found 57 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
PARTITION_MANAGER: Failed to publish partition.
I> Found 11 partitions in SDMMC_USER (instance 3)
I> Task: Load and authenticate registered FWs (0x50012818)
I> Task: Load AUXP FWs (0x5001aa7c)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-56320 (partition size: 0x90000), name: A_spe-fw
E> Binary spe is not found in comp table
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-57472 (partition size: 0x100000), name: A_rce-fw
E> Binary rce is not found in comp table
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0xba400000
I> Partition name: A_dce-fw
I> Size of partition: 9437184
I> Binary@ device:3/0 block-37888 (partition size: 0x900000), name: A_dce-fw
E> Binary dce is not found in comp table
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0xba100000
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-59520 (partition size: 0x200000), name: A_adsp-fw
E> Binary ape is not found in comp table
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0xc6000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-10368 (partition size: 0x40000), name: A_xusb-fw
E> Binary xusb is not found in comp table
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0xbb400000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0xba500000
I> Task: Carveout setup (0x50014018)
I> Program remaining OEM carveouts
I> Task: Restore XUSB sec (0x50001c30)
I> Task: OEM firewalls (0x50017ee0)
I> MB2-BCT Firewall data is empty
I> Task: Unhalt AUXPs (0x5001ace4)
I> Unhalting SPE…
I> Enabling combined UART
?跴pe: early_init
vic initialized
tsc initialized
aon lic initialized
spe: tag is 9f1f07bc2d4b6509c13554672acefaad
spe: SafeRTOS v8.4
spe: init
scheduler initialized
aon hsp initialized
tag initialized
tcu initialized
bpmp ipc initialized
spe: late init
cpu_nic clock initialized
apb clock initialized
pm initialized
bpmp hsp initialized
top1 hsp initialized
ccplex ipc initialized
spe: start scheduler
?I> Task: Trigger mailbox for PSC-BL1 exit (0x5000e660)
I> Sending opcode 0x4d420802 to psc
艐NFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0xbb000000 SIZE:0x400000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: a796142-39d6527-7490c54-dev
嘌> Received ACK from psc
艐NFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
INFO: pllpsc is already locked.
INFO: MONITOR: user task addr:0xbb022000, blob offset:0x00020000
嘌> Task: Start secure NOR provision (0x50010b3c)
I> Task: Load FSI keyblob (0x5000ea28)
I> Skipping FSI key blob??copy
I> Task: Enable FSITHERM (0x5000e5b4)
I> Task: Unhalt AUXPs (0x5001acec)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> DCE unhalt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x5000f7c4)
I> Task: Load TOS (0x5000fe50)
I> Scratch RSV109: 0x00000001 active chain: 0槆pmp: init
bpmp: base binary md5 is f0425a554b39d571b1bbb5291283d946
bpmp: combined binary md5 is 43f75b5aad2b8e1992e4e049bafc8696
bpmp: firmware tag is 43嬂 2.440535] Camera-FW on t234-rce-safe started
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-17920 (partition size: 0x380000), name: A_cpu-bootloader
嫿CU early console enabled.
殞75b5aad2b8e1992e4-f0425a554b3
initialized vwdt
匰> Binary cpubl is no艐NFO: MONITOR: populated user images:16
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init…
INFO: enter idle task.
毃nitialized clk_mach_early
initialized mail_early
initialized fuse
嫢 found in comp table毃nitialized vfrel
initialized hwwdt
initialized adc
殞mon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
469 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized thermal
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_嘌> Scratch RSV109: 0x歊hk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
initialized avfs_clk_platform
?0000001 active ch毃nitialized powergate墑in: 0
I> Partition name: A_secure-os
I> Size of part?
initialized dvs
initialized clk_mach_config
initialized pm
initialized suspend
initialized strap
initialized emc
initialized emc_mrq
WARNING @ [platform/drivers/clk/clk-fwk壾tion: 4194304
I> Binary@ device:3/0 block-25088 (part?clk-cal.c]: aon_apb 壾tion size: 0x400000), name: A_secure-os
毃s not configured by BPMP-FW
WARNING @ [platform/drivers/clk/clk-fwk/clk-cal.c]: aon_cpu_nic is not configured by匰> Binary tos is not found in comp table
?BPMP-FW
initialized clk_cal
ini嘌> MB2-params @ 0x40060000
I> CPUBL-params @ 0xc200000漮ialized uphy_dt
ini?
漮ialized uphy_mrq
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_init: 0 reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
initialized mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
initialized clk_cal_late
initialized noc_late
initialized dbells
initialized dmce
initialized cvc
initialized avfs_clk_mach_post
ini嘌> cpubl: Authenticat嬂 2.674615] Camera-FW on t234-rce-safe ready SHA1=ab261c6c (crt 16.694 ms,壾on Finalize Done
I> Binary cpubl loaded successfully 漮ialized pm_post
ini墑t 0xba800000
漮ialized avfs_clk_platform_post
initialized cvc_late
initia?total boot 251.829 ms)
嘌> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0xbeee7000滎ized rm
initialized console_late
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized ?
漥rofile
initialized fuse_late
initialized extras_post
bpmp: init complete
嘌> Task: Prepare TOS params (0x5000fdcc)
I> Task: OEM SC7 context save (0x50010878)
踜CE: FW Boot Done
嘌> oem sc7 context saved
I> Task: Disable MSS perf stats (0x5001ad78)
I> Task: Program display sticky bits (0x5001acf4)
I> Task: Storage device deinit (0x50001ca4)
I> Task: SMMU init (0x5001a738)
I> Task: Program CBB PCIE AMAP regions (0x500031dc)
I> Task: Program GICv3 registers (0x5001ae18)
I> Task: Audit firewall settings (0x5001816c)
I> MB2 finished
誏OTICE: BL31: v2.5(release):ef8af0b99
NOTICE: BL31: Built : 20:58:00, May 16 2022
ERROR: Error initializing runtime service trusty_fast
?Jetson UEFI firmware (version r34.1-975eef6 built on 2022-05-16T20:58:45-07:00)
覟RROR: Exception reason=0 syndrome=0xbe000411
ERROR: **************************************
ERROR: RAS Uncorrectable Error in IOB, base=0xe010000:
ERROR: Status = 0xe4000612
ERROR: SERR = Error response from slave: 0x12
ERROR: IERR = CBB Interface Error: 0x6
ERROR: MISC0 = 0x44020040
ERROR: MISC1 = 0x58d4860000000000
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
ERROR: ADDR = 0x8000000013800800
ERROR: sdei_dispatch_event returned -1
This would be fixed in next release.
