I have followed design guidence to layout my customer board,but an error occurs in every booting: “[ 164.608747] Generic FE-GE Realtek PHY r8169-8-100:00: Downshift occurred from negotiated speed 1Gbps to actual speed 100Mbps, check cabling!”
Is there something wrong with my settings?
Hi g_shilong,
Could you help to refer the following steps to load downstream driver(r8168) instead of upstream driver(r8169) and check if it could help?
$ sudo su # cd /lib/modules/5.10.104-tegra/kernel/drivers/net/ethernet/realtek/ # mv r8169.ko r8169_temp.ko # reboot
Please also share the dmesg after reboot for further check.
