PCIe CLKREQ#
What is the pull-up level for CLKREQ# of JETSON AGX XAVIER ? …Shall I connect it with 3.3V Pull up?
There is 3.3v pull-up in module, no need to add external pull-up.
is the pullup in Jetson Xavier carrier card or on the SOM? Because I’m going to use only SOM for my design and all the connections on the CVM connector will be utilized. In that case do I need to add pull up?
In the module.
Thanks for the info.
