I have a TK1 connected to a modem that is handled by ModemManager and eventually pppd. The system usually operates as expected by booting, connecting to a network and remaining connected to a network until shutdown. In around 10% of the trials the network connection fails. This usually also causes most mmcli commands to hang. Inspecting dmesg given below reveals a kernel panic related to pppd. The error occurs at 725.097917
Any suggestions or pointers to how I can identify and in the ideal case fix the error is highly appreciated.
ubuntu@tegra-ubuntu:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.40-2.8.3+g6c533d3 (oe-user@oe-host) (gcc version 7.3.0 (GCC) ) #1 SMP PREEMPT Tue Jun 26 21:38:58 UTC 2018
[ 0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=30c7387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: apalis-tk1, model: Toradex Apalis TK1 on Apalis Evaluation Board, serial: 0
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: f46ff000 - f46ff80f
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: fa500000 - fb6fffff
[ 0.000000] 2nd Framebuffer: fb700000 - ffefffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Tsec: 00000000 - 00000000
[ 0.000000] cma: CMA: reserved 16 MiB at ae800000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] On node 0 totalpages: 500480
[ 0.000000] free_area_init_node: node 0, pgdat c0b38f00, node_mem_map c0c09000
[ 0.000000] DMA zone: 1520 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 194560 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2574 pages used for memmap
[ 0.000000] HighMem zone: 305920 pages, LIFO batch:31
[ 0.000000] DTS File Name: /workdir/oe/tmp-glibc/work-shared/apalis-tk1/kernel-source/arch/arm/boot/dts/tegra124-apalis-v1.2-eval.dts
[ 0.000000] Tegra12: CPU Speedo value 2264, Soc Speedo value 2204, Gpu Speedo value 2071
[ 0.000000] Tegra12: CPU Speedo ID 5, Soc Speedo ID 0, Gpu Speedo ID 1
[ 0.000000] Tegra12: CPU Process ID 0,Soc Process ID 1,Gpu Process ID 0
[ 0.000000] Tegra Revision: A01 SKU: 0x87 CPU Process: 0 Core Process: 1
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[ 0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1044000000
[ 0.000000] Lowering sbus maximum rate from 420000000 to 372000000
[ 0.000000] Lowering vic03 maximum rate from 900000000 to 756000000
[ 0.000000] Lowering tsec maximum rate from 900000000 to 756000000
[ 0.000000] Lowering msenc maximum rate from 600000000 to 480000000
[ 0.000000] Lowering se maximum rate from 600000000 to 480000000
[ 0.000000] Lowering vde maximum rate from 600000000 to 480000000
[ 0.000000] Lowering host1x maximum rate from 500000000 to 408000000
[ 0.000000] Lowering vi maximum rate from 700000000 to 600000000
[ 0.000000] Lowering isp maximum rate from 700000000 to 600000000
[ 0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[ 0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 2065500000
[ 0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1c30000 s15156 r8192 d13516 u36864
[ 0.000000] pcpu-alloc: s15156 r8192 d13516 u36864 alloc=9*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 498960
[ 0.000000] Kernel command line: lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 pcie_aspm=off user_debug=30 ip=off root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait igb_mac=00:14:2d:2e:85:31 consoleblank=0 no_console_suspend=1 console=tty1 console=ttyS0,115200n8 debug_uartport=lsport,0 video=tegrafb0:640x480-16@60 fbcon=map:1
[ 0.000000] PCIe ASPM is disabled
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1955MB = 1955MB total
[ 0.000000] Memory: 1955612k/1955612k available, 140516k reserved, 1223676K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc09ec840 (10131 kB)
[ 0.000000] .init : 0xc09ed000 - 0xc0a5fb34 ( 459 kB)
[ 0.000000] .data : 0xc0a60000 - 0xc0b4d860 ( 951 kB)
[ 0.000000] .bss : 0xc0b4d860 - 0xc0be8a38 ( 621 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:960
[ 0.000000] the number of interrupt controllers found is 5
[ 0.000000] Architected local timer running at 12.00MHz (phys).
[ 0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
[ 0.000000] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.003521] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=12000
[ 0.003589] pid_max: default: 32768 minimum: 301
[ 0.003932] Mount-cache hash table entries: 512
[ 0.025917] Initializing cgroup subsys debug
[ 0.025961] Initializing cgroup subsys freezer
[ 0.026041] CPU: Testing write buffer coherency: ok
[ 0.026112] ftrace: allocating 30364 entries in 60 pages
[ 0.067249] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.067291] Setting up static identity map for 0xc07217d8 - 0xc0721868
[ 0.071273] ftrace: Allocated trace_printk buffers
[ 0.078954] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.081978] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.085004] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.085205] Brought up 4 CPUs
[ 0.085268] SMP: Total of 4 processors activated.
[ 0.085285] CPU: All CPU(s) started in SVC mode.
[ 0.086398] devtmpfs: initialized
[ 0.095260] pinctrl core: initialized pinctrl subsystem
[ 0.095657] regulator-dummy: no parameters
[ 0.096519] NET: Registered protocol family 16
[ 0.098831] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.100154] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[ 0.101216] console [pstore-1] enabled
[ 0.101257] ramoops: attached 0x200000@0xfa300000, ecc: 0/0
[ 0.101665] cpuidle: using governor ladder
[ 0.101688] cpuidle: using governor menu
[ 0.105005] apalis_tk1_camera_auxdata: update camera lookup table.
[ 0.114515] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[ 0.114973] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.122671] Wake16 for irq=34
[ 0.128943] platform tegradc.0: IOVA linear map 0x00000000fa500000(1200000)
[ 0.132306] platform tegradc.0: IOVA linear map 0x00000000fb700000(4800000)
[ 0.137494] platform tegradc.1: IOVA linear map 0x00000000fa500000(1200000)
[ 0.140842] platform tegradc.1: IOVA linear map 0x00000000fb700000(4800000)
[ 0.142798] Wake58 for irq=81
[ 0.142849] Wake41 for irq=129
[ 0.142867] Wake43 for irq=129
[ 0.142914] Wake40 for irq=53
[ 0.142931] Wake42 for irq=53
[ 0.146022] Selecting UARTA as the debug console
[ 0.146077] The debug console clock name is uarta
[ 0.147924] PMC DT attribute sysclkreq_high=0, board value=1
[ 0.147948] PMC DT attribute corereq_high=0, board value=1
[ 0.147970] PMC DT attribute cpu_off_timer=0, board value=300
[ 0.147992] PMC DT attribute cpu_timer=0, board value=500
[ 0.148012] PMC DT attribute suspend_mode=0, board value=2
[ 0.148500] Clear bootloader IO dpd settings
[ 0.148668] Loading Apalis TK1 EMC tables.
[ 0.148918] tegra: pll_m is selected as scalable EMC clock source
[ 0.148963] Lowering emc maximum rate from 1200000000 to 924000000
[ 0.148991] tegra: validated EMC DFS table
[ 0.149085] apalis_tk1_edp_init: CPU regulator 12500 mA
[ 0.416614] apalis_tk1_edp_init: GPU regulator 11400 mA
[ 0.417637] swapper/0 isomgr_init(): iso emc max clk=924000KHz
[ 0.417657] swapper/0 isomgr_init(): max_iso_bw=7392000KB<6>[ 0.496421] FUSE: cp_rev 0 ft_rev 0
[ 0.496608] tegra11_soctherem_oc_int_init(): OC interrupts are not enabled
[ 0.496838] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.496869] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.497226] mc-err: Started MC error interface!
[ 0.507563] bio: create slab <bio-0> at 0
[ 0.508824] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
[ 0.508861] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
[ 0.508892] of_get_named_gpio_flags: can't parse gpios property
[ 0.508994] +V3.3_MXM: 3300 mV
[ 0.509847] SCSI subsystem initialized
[ 0.510041] libata version 3.00 loaded.
[ 0.510230] usbcore: registered new interface driver usbfs
[ 0.510298] usbcore: registered new interface driver hub
[ 0.510426] usbcore: registered new device driver usb
[ 0.510637] of_get_named_gpio_flags exited with status 20
[ 0.510656] of_get_named_gpio_flags exited with status 21
[ 0.511971] of_get_named_gpio_flags exited with status 157
[ 0.511991] of_get_named_gpio_flags exited with status 158
[ 0.512233] of_get_named_gpio_flags exited with status 217
[ 0.512251] of_get_named_gpio_flags exited with status 218
[ 0.512484] of_get_named_gpio_flags exited with status 172
[ 0.512502] of_get_named_gpio_flags exited with status 173
[ 0.514054] of_get_named_gpio_flags exited with status 206
[ 0.514072] of_get_named_gpio_flags exited with status 207
[ 0.514477] Wake18 for irq=118
[ 0.515431] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x05
[ 0.515462] as3722 4-0040: Device version 1V1 and platform version 1V2
[ 0.515488] as3722 4-0040: Final OTP version 1V2
[ 0.516328] Wake18 for irq=118
[ 0.519326] gpiochip_find_base: found new base at 1016
[ 0.519423] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
[ 0.519458] GPIO chip as3722-gpio: created GPIO range 0->7 ==> as3722-pinctrl PIN 0->7
[ 0.519636] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.519699] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.519757] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.519789] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.519821] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.519852] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.519925] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.519980] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.520013] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.520091] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.520122] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.520153] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.520184] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.520216] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.520249] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.520281] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.520312] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.520343] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.520375] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
[ 0.520406] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[ 0.520438] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
[ 0.520469] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
[ 0.520500] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
[ 0.520532] as3722-regulator as3722-regulator.0: Consumer c16 does not have device name
[ 0.520569] as3722-regulator as3722-regulator.0: Consumer c19 does not have device name
[ 0.520600] as3722-regulator as3722-regulator.0: Consumer c20 does not have device name
[ 0.520631] as3722-regulator as3722-regulator.0: Consumer c21 does not have device name
[ 0.520663] as3722-regulator as3722-regulator.0: Consumer c22 does not have device name
[ 0.520741] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.520772] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.520831] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.520862] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.520893] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.520924] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.520955] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.521003] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.521035] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.521066] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.521097] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.521151] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.521229] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.521261] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.521292] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.521326] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[ 0.521381] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.521435] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.521467] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.521498] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.521552] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.522513] +VDD_CPU_AP: 650 <--> 1300 mV at 1000 mV 3500 mA
[ 0.523286] +VDD_CORE: applied init 1150000uV constraint
[ 0.523891] +VDD_CORE: 700 <--> 1350 mV at 1150 mV 3500 mA
[ 0.525074] +V1.35_VDDIO_DDR(sd2): 1350 mV
[ 0.525410] as3722-sd3: no parameters
[ 0.525725] +V1.05: 1050 mV
[ 0.526619] +V1.8: 1800 mV
[ 0.526989] +VDD_GPU_AP: applied init 1000000uV constraint
[ 0.527871] +VDD_GPU_AP: 650 <--> 1200 mV at 1000 mV 3500 mA
[ 0.528406] +V1.05_AVDD: 1050 mV at 300 mA
[ 0.529242] VDDIO_SDMMC1: 1800 <--> 3300 mV at 3300 mV at 150 mA
[ 0.529913] +V1.2: 1200 mV at 150 mA
[ 0.531156] +V1.05_RTC: 1000 mV at 150 mA
[ 0.531628] AVDD_LVDS0_PLL: applied init 1800000uV constraint
[ 0.531668] AVDD_LVDS0_PLL: 1800 <--> 3300 mV at 1800 mV at 150 mA
[ 0.532023] as3722-ldo5: at 150 mA
[ 0.532404] VDDIO_SDMMC3: 1800 <--> 3300 mV at 150 mA
[ 0.532750] as3722-ldo7: at 150 mA
[ 0.533413] +V3.3_ETH(ldo9): 3300 mV at 150 mA
[ 0.533906] +V3.3_ETH(ldo10): 3300 mV at 150 mA
[ 0.534400] +V1.8_VPP_FUSE: 1800 mV at 150 mA
[ 0.534987] of_get_named_gpio_flags: can't parse gpios property
[ 0.534998] of_get_named_gpio_flags: can't parse gpios property
[ 0.535468] Linux video capture interface: v2.00
[ 0.535526] pps_core: LinuxPPS API ver. 1 registered
[ 0.535547] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.535592] PTP clock support registered
[ 0.536431] Advanced Linux Sound Architecture Driver Initialized.
[ 0.537277] of_get_named_gpio_flags exited with status 63
[ 0.537401] +V1.05_AVDD_HDMI_PLL: 1050 mV
[ 0.537455] +V1.05_AVDD_HDMI_PLL: supplied by +V1.05
[ 0.537673] reg-fixed-sync-voltage 2.regulator: Consumer c7 does not have device name
[ 0.537710] reg-fixed-sync-voltage 2.regulator: Consumer c8 does not have device name
[ 0.537749] reg-fixed-sync-voltage 2.regulator: Consumer c11 does not have device name
[ 0.537790] reg-fixed-sync-voltage 2.regulator: Consumer c15 does not have device name
[ 0.537823] reg-fixed-sync-voltage 2.regulator: Consumer c16 does not have device name
[ 0.537855] reg-fixed-sync-voltage 2.regulator: Consumer c17 does not have device name
[ 0.537888] reg-fixed-sync-voltage 2.regulator: Consumer c18 does not have device name
[ 0.537934] of_get_named_gpio_flags exited with status 1018
[ 0.538644] +V3.3: 3300 mV
[ 0.538923] reg-fixed-sync-voltage 3.regulator: Consumer c3 does not have device name
[ 0.538956] of_get_named_gpio_flags: can't parse gpios property
[ 0.539075] 5V_SW: 5000 mV
[ 0.539277] of_get_named_gpio_flags exited with status 157
[ 0.539397] VCC_USBO1: 5000 mV
[ 0.539604] of_get_named_gpio_flags exited with status 158
[ 0.539711] VCC_USBH(2A|2C|2D|3|4): 5000 mV
[ 0.542755] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is connected
[ 0.545218] tegra: failed to map regulator to power detect cell pwrdet_cam(-517)
[ 0.545258] tegra: failed to map regulator to power detect cell pwrdet_pex_ctl(-517)
[ 0.545607] tegra: failed regulators mapping - io power detection is left always on
[ 0.545640] Switching to clocksource arch_sys_counter
[ 0.568388] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.568568] nvmap_page_pool_init: Total MB RAM: 1925
[ 0.568592] nvmap_page_pool_init: nvmap page pool size: 61624 pages (240 MB)
[ 0.568749] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.568925] iram: dma coherent mem declare 0x0000000040001000,258048
[ 0.569793] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[ 0.569957] nvmap:inner cache maint threshold=2097152
[ 0.580065] Wake39 for irq=52
[ 0.580157] tegra-otg tegra-otg: otg transceiver registered
[ 0.580527] NET: Registered protocol family 2
[ 0.581301] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.581505] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.581719] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.581785] TCP: reno registered
[ 0.581810] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.581867] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.582237] NET: Registered protocol family 1
[ 0.582653] RPC: Registered named UNIX socket transport module.
[ 0.582679] RPC: Registered udp transport module.
[ 0.582719] RPC: Registered tcp transport module.
[ 0.582739] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.582765] PCI: CLS 0 bytes, default 64
[ 0.583044] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 0.588740] host1x host1x: initialized
[ 0.589893] CPU PMU: probing PMU on CPU 0
[ 0.589928] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.590553] tegra_throttle : init passed
[ 0.590673] Tegra cpuquiet initialized: disabled
[ 0.590836] cpu-tegra: init EDP limit: 2065 MHz
[ 0.591864] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.592288] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.592537] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[ 0.592824] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.594450] bounce pool size: 64 pages
[ 0.596183] NFS: Registering the id_resolver key type
[ 0.596237] Key type id_resolver registered
[ 0.596259] Key type id_legacy registered
[ 0.596290] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.596952] NTFS driver 2.1.30 [Flags: R/O].
[ 0.597256] fuse init (API version 7.22)
[ 0.597650] msgmni has been set to 1461
[ 0.600081] io scheduler noop registered (default)
[ 0.600422] of_get_named_gpio_flags: can't parse gpios property
[ 0.600434] of_get_named_gpio_flags: can't parse gpios property
[ 0.600444] of_get_named_gpio_flags: can't parse gpios property
[ 0.600529] PCIE.C: tegra_pcie_enable_regulators : regulator hvdd_pex
[ 0.600625] PCIE.C: tegra_pcie_enable_regulators : regulator pexio
[ 0.600727] PCIE.C: tegra_pcie_enable_regulators : regulator avdd_plle
[ 1.306955] PCIE: port 0: link down, retrying
[ 1.709151] PCIE: port 0: link down, retrying
[ 2.111331] PCIE: port 0: link down, retrying
[ 2.313427] PCIE: port 0: link down, ignoring
[ 2.327604] PCI host bridge to bus 0000:00
[ 2.327634] pci_bus 0000:00: root bus resource [mem 0x32100000-0x3fffffff]
[ 2.327662] pci_bus 0000:00: root bus resource [mem 0x12100000-0x320fffff pref]
[ 2.327693] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 2.327740] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 2.327800] pci 0000:00:00.0: [10de:0e13] type 01 class 0x060400
[ 2.327895] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.328137] PCI: bus0: Fast back to back transfers disabled
[ 2.328167] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.328384] pci 0000:01:00.0: [8086:157b] type 00 class 0x020000
[ 2.328424] pci 0000:01:00.0: reg 10: [mem 0x00000000-0x0001ffff]
[ 2.328471] pci 0000:01:00.0: reg 18: [io 0x0000-0x001f]
[ 2.328500] pci 0000:01:00.0: reg 1c: [mem 0x00000000-0x00003fff]
[ 2.328657] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 2.328872] PCI: bus1: Fast back to back transfers disabled
[ 2.328903] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.328920] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 01
[ 2.329214] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.329244] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.329274] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
[ 2.329398] aer 0000:00:00.0:pcie02: service driver aer loaded
[ 2.329499] pcieport 0000:00:00.0: BAR 8: assigned [mem 0x32100000-0x321fffff]
[ 2.329535] pcieport 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 2.329568] pci 0000:01:00.0: BAR 0: assigned [mem 0x32100000-0x3211ffff]
[ 2.329602] pci 0000:01:00.0: BAR 3: assigned [mem 0x32120000-0x32123fff]
[ 2.329635] pci 0000:01:00.0: BAR 2: assigned [io 0x1000-0x101f]
[ 2.329667] pcieport 0000:00:00.0: PCI bridge to [bus 01]
[ 2.329693] pcieport 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 2.329745] pcieport 0000:00:00.0: bridge window [mem 0x32100000-0x321fffff]
[ 2.329789] PCIE: No Link speed change happened
[ 2.329817] PCIE: ASPM not enabled
[ 2.330210] of_get_named_gpio_flags exited with status 221
[ 2.330397] sysedp_create_consumer: unable to create backlight.3, no consumer_data for backlight.3 found
[ 2.331410] tsec tsec: initialized
[ 2.332912] isp isp.0: initialized
[ 2.333935] isp isp.1: initialized
[ 2.335563] falcon vic03.0: initialized
[ 2.336833] falcon msenc: initialized
[ 2.337329] of_dc_parse_platform_data: could not find SD settings node
[ 2.337357] of_dc_parse_platform_data: could not find cmu node
[ 2.337573] tegradc tegradc.0: using mode 1280x800 pclk=71100000 href=1 vref=1
[ 2.339772] tegradc tegradc.0: nominal-pclk:71100000 parent:71000000 div:1.0 pclk:71000000 70389000~77499000
[ 2.357229] tegradc tegradc.0: probed
[ 2.357417] tegradc tegradc.0: parse cmd options for tegrafb0: 640x480-16@60
[ 2.357455] tegradc tegradc.0: switching framebuffer to 640x480
[ 2.357483] tegradc tegradc.0: Calculated sync href=0 vref=1
[ 2.357509] tegradc tegradc.0: using mode 640x480 pclk=25175000 href=0 vref=1
[ 2.359985] tegradc tegradc.0: nominal-pclk:25175000 parent:25125000 div:1.0 pclk:25125000 24923250~27440750
[ 2.377262] tegradc tegradc.0: fb registered
[ 2.377503] of_get_named_gpio_flags exited with status 111
[ 2.377520] of_dc_parse_platform_data: could not find SD settings node
[ 2.377545] of_dc_parse_platform_data: could not find cmu node
[ 2.377802] tegradc tegradc.1: using mode 640x480 pclk=25200000 href=1 vref=1
[ 2.378302] gpio wake4 for gpio=111
[ 2.379728] tegra-i2c tegra12-i2c.3: no acknowledge from address 0x50
[ 2.382654] tegradc tegradc.1: probed
[ 2.383805] tegradc tegradc.1: switching framebuffer to 640x480
[ 2.383838] tegradc tegradc.1: using mode 640x480 pclk=25200000 href=1 vref=1
[ 2.384136] tegradc tegradc.1: switching framebuffer to 640x480
[ 2.384145] tegradc tegradc.1: using mode 640x480 pclk=25200000 href=1 vref=1
[ 2.387369] Console: switching to colour frame buffer device 80x30
[ 2.396740] tegradc tegradc.1: fb registered
[ 2.398858] hdmi_state_machine_worker (tid edb03080): state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 2.403254] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 2.406942] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 2.407667] Serial: 8250/16550 driver, 9 ports, IRQ sharing disabled
[ 2.409913] serial8250.0: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
[ 2.456745] hdmi_state_machine_worker (tid edb03080): state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 2.456750] hdmi_disable_l: audio_switch 0
[ 2.456752] hdmi_disable_l: hpd_switch 0
[ 2.456758] hdmi_state_machine_set_state_l: switching from state 0 (Reset) to state 1 (Check Plug)
[ 2.466735] hdmi_state_machine_worker (tid edb03080): state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 2.466738] hdmi_disable_l: audio_switch 0
[ 2.466741] hdmi_disable_l: hpd_switch 0
[ 2.466747] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 4.576570] console [ttyS0] enabled
[ 4.582825] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 4.595504] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 4.608365] serial-tegra.3: ttyTHS3 at MMIO 0x70006300 (irq = 122) is a SERIAL_TEGRA
[ 4.626412] loop: module loaded
[ 4.632197] nct1008_nct72 4-004c: success in enabling rail vdd_nct72
[ 4.644259] gpio wake35 for gpio=70
[ 4.650348] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 4.659249] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 4.674151] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 4.689873] tegra_profiler: Branch: Dev
[ 4.696374] tegra_profiler: Version: 1.103
[ 4.703099] tegra_profiler: Samples version: 34
[ 4.710263] tegra_profiler: IO version: 18
[ 4.716932] armv7_pmu: arch: Cortex A15, type: 4, ver: 0
[ 4.724969] tegra_profiler: auth: init
[ 4.731608] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[ 4.741129] tegra-sata tegra-sata.0: version 1.0
[ 4.741143] of_get_named_gpio_flags: can't parse gpios property
[ 4.741808] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 4.755995] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[ 4.770656] scsi0 : tegra-sata
[ 4.776549] scsi1 : tegra-sata
[ 4.782158] ata1: SATA max UDMA/133 irq 55
[ 4.788633] ata2: DUMMY
[ 4.795334] gpio wake34 for gpio=82
[ 4.803387] tun: Universal TUN/TAP device driver, 1.6
[ 4.810670] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.819215] CAN device driver interface
[ 4.825279] Intel(R) Gigabit Ethernet Network Driver - version 5.3.5.4
[ 4.833973] Copyright (c) 2007-2015 Intel Corporation.
[ 4.883074] igb 0000:01:00.0: added PHC on eth0
[ 4.889780] igb 0000:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 4.898823] igb 0000:01:00.0: eth0: (PCIe:2.5GT/s:Width x1)
[ 4.906618] igb 0000:01:00.0 eth0: MAC: 00:14:2d:2e:85:31
[ 4.914147] igb 0000:01:00.0: eth0: PBA No: Unknown
[ 4.921088] igb 0000:01:00.0: LRO is disabled
[ 4.927422] igb 0000:01:00.0: Using MSI-X interrupts. 1 rx queue(s), 1 tx queue(s)
[ 4.938943] usbcore: registered new interface driver asix
[ 4.946362] usbcore: registered new interface driver ax88179_178a
[ 4.954479] usbcore: registered new interface driver cdc_ether
[ 4.962344] usbcore: registered new interface driver cdc_subset
[ 4.970243] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.978923] ehci-pci: EHCI PCI platform driver
[ 4.985618] tegra_xusb_read_usb_calib: usb_calib0 = 0x02c5838b
[ 4.993847] usbcore: registered new interface driver usb-storage
[ 5.001920] usbcore: registered new interface driver usbserial
[ 5.009838] usbcore: registered new interface driver usbserial_generic
[ 5.018221] usbserial: USB Serial support registered for generic
[ 5.026093] usbcore: registered new interface driver pl2303
[ 5.033766] usbserial: USB Serial support registered for pl2303
[ 5.041636] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 5.052859] tegra USB phy - inst[0] platform info:
[ 5.059630] port_otg: yes
[ 5.064187] has_hostpc: yes
[ 5.068875] phy_interface: USB_PHY_INTF_UTMI
[ 5.075035] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 5.081156] qc2_voltage: 0
[ 5.085660] vbus_pmu_irq: 0
[ 5.090226] vbus_gpio: -1
[ 5.094568] charging: disabled
[ 5.097756] ata1: SATA link down (SStatus 0 SControl 300)
[ 5.106431] remote_wakeup: disabled
[ 5.116992] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 5.132944] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[ 5.141533] as3722-rtc as3722-rtc.1: RTC interrupt 449
[ 5.280739] otg state changed: SUSPEND --> HOST
[ 5.287317] tegra USB phy - inst[0] platform info:
[ 5.294002] port_otg: yes
[ 5.298519] has_hostpc: yes
[ 5.303154] phy_interface: USB_PHY_INTF_UTMI
[ 5.309262] op_mode: TEGRA_USB_OPMODE_HOST
[ 5.315167] qc2_voltage: 0
[ 5.319637] vbus_gpio: -1
[ 5.324021] hot_plug: disabled
[ 5.328855] remote_wakeup: enabled
[ 6.149726] tegra-i2c tegra12-i2c.0: --- register dump for debugging ----
[ 6.158340] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 6.165257] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 6.173925] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 6.181285] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 6.188869] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 6.195855] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 6.202890] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 6.209206] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 6.215882] tegra-i2c tegra12-i2c.0: next_msg->len - 8
[ 6.222604] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 6.229684] tegra-i2c tegra12-i2c.0: buf_remaining - 8
[ 6.236451] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x0068, data 0x00
[ 6.247416] rtc-ds1307: probe of 0-0068 failed with error -5
[ 6.255187] tegra_rtc tegra_rtc: rtc core: registered tegra_rtc as rtc1
[ 6.263540] Wake16 for irq=34
[ 6.268148] tegra_rtc tegra_rtc: Tegra internal Real Time Clock
[ 6.275776] i2c /dev entries driver
[ 6.284024] nvavp nvavp: allocated IOVA at 8ff00000 for AVP os
[ 6.292177] tegra_dtv_probe: probing dtv.
[ 6.297922] setup_stream: bufsize = 4096, bufnum = 4
[ 6.303142] usbcore: registered new interface driver uvcvideo
[ 6.312389] USB Video Class driver (1.1.1)
[ 6.318613] zram: Created 1 device(s) ...
[ 6.325052] tegra_wdt tegra_wdt.0: last reset is due to power on reset
[ 6.333519] WDT heartbeat enabled on probe
[ 6.338448] tegra-ehci tegra-ehci.0: Tegra EHCI Host Controller
[ 6.338476] tegra-ehci tegra-ehci.0: new USB bus registered, assigned bus number 1
[ 6.338599] tegra-ehci tegra-ehci.0: irq 52, io mem 0x7d000000
[ 6.340748] tegra-ehci tegra-ehci.0: USB 2.0 started, EHCI 1.10
[ 6.340838] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.340846] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.340852] usb usb1: Product: Tegra EHCI Host Controller
[ 6.340858] usb usb1: Manufacturer: Linux 3.10.40-2.8.3+g6c533d3 ehci_hcd
[ 6.340863] usb usb1: SerialNumber: tegra-ehci.0
[ 6.417070] tegra_wdt_probe done
[ 6.417511] hub 1-0:1.0: USB hub found
[ 6.417535] hub 1-0:1.0: 1 port detected
[ 6.434747] sdhci: Secure Digital Host Controller Interface driver
[ 6.443186] sdhci: Copyright(c) Pierre Ossman
[ 6.449712] sdhci-pltfm: SDHCI platform and OF driver helper
[ 6.457864] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[ 6.473137] sdhci-tegra sdhci-tegra.3: Speedo value 2204
[ 6.480640] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1150
[ 6.494598] mmc0: no vqmmc regulator found
[ 6.500875] mmc0: no vmmc regulator found
[ 6.507023] mmc0: Invalid maximum block size, assuming 512 bytes
[ 6.515238] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[ 6.550738] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 6.565563] sdhci-tegra sdhci-tegra.0: Speedo value 2204
[ 6.573181] sdhci-tegra sdhci-tegra.0: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1150
[ 6.587355] mmc1: no vqmmc regulator found
[ 6.593776] mmc1: no vmmc regulator found
[ 6.600080] mmc1: Invalid maximum block size, assuming 512 bytes
[ 6.608473] sysedp_create_consumer: unable to create sdhci-tegra.0, no consumer_data for sdhci-tegra.0 found
[ 6.644738] mmc1: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA
[ 6.659760] sdhci-tegra sdhci-tegra.2: Speedo value 2204
[ 6.667409] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1150
[ 6.681681] mmc2: no vqmmc regulator found
[ 6.688236] mmc2: no vmmc regulator found
[ 6.694632] mmc2: Invalid maximum block size, assuming 512 bytes
[ 6.726895] mmc0: BKOPS_EN bit is not set
[ 6.736146] mmc0: new high speed DDR MMC card at address 0001
[ 6.703125] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found
[ 6.744376] mmc2: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[ 6.759152] gpio wake56 for gpio=170
[ 6.759208] mmcblk mmc0:0001: Card claimed for testing.
[ 6.772956] mmcblk0: mmc0:0001 016G30 14.6 GiB
[ 6.780171] mmcblk0boot0: mmc0:0001 016G30 partition 1 4.00 MiB
[ 6.788763] mmcblk0boot1: mmc0:0001 016G30 partition 2 4.00 MiB
[ 6.797225] mmcblk0rpmb: mmc0:0001 016G30 partition 3 4.00 MiB
[ 6.806808] mmcblk0: p1 p2
[ 6.806900] tegra-se tegra12-se: tegra_se_probe: complete
[ 6.807095] hidraw: raw HID events driver (C) Jiri Kosina
[ 6.807211] usbcore: registered new interface driver usbhid
[ 6.807214] usbhid: USB HID core driver
[ 6.841229] tegra-hier-ictlr tegra-hier-ictlr: probed
[ 6.849464] mmcblk0boot1: unknown partition table
[ 6.858114] mmcblk0boot0: unknown partition table
[ 6.928355] usbcore: registered new interface driver snd-usb-audio
[ 6.937722] tegra_offload_platform probe successfull.
[ 6.945090] succefully registered offload opstegra30_avp_audio_platform_probe successful.
[ 6.958395] sgtl5000 4-000a: sgtl5000 revision 0x11
[ 6.967928] 4-000a: 1200 mV normal
[ 6.973744] sgtl5000 4-000a: Using internal LDO instead of VDDD
[ 6.986778] tegra-snd-apalis-tk1-sgtl5000 tegra-snd-apalis-tk1-sgtl5000.0: sgtl5000 <-> tegra30-i2s.2 mapping ok
[ 7.001902] tegra-snd-apalis-tk1-sgtl5000 tegra-snd-apalis-tk1-sgtl5000.0: dit-hifi <-> tegra30-spdif mapping ok
[ 7.018607] oprofile: using timer interrupt.
[ 7.025212] GACT probability NOT on
[ 7.030850] Mirror/redirect action on
[ 7.036599] u32 classifier
[ 7.041543] Actions configured
[ 7.046988] Netfilter messages via NETLINK v0.30.
[ 7.053766] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 7.062327] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 7.071424] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 7.079749] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 7.087366] arp_tables: (C) 2002 David S. Miller
[ 7.094184] TCP: cubic registered
[ 7.099805] NET: Registered protocol family 10
[ 7.107302] mip6: Mobile IPv6
[ 7.112381] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 7.120558] NET: Registered protocol family 17
[ 7.127134] NET: Registered protocol family 15
[ 7.133633] can: controller area network core (rev 20120528 abi 9)
[ 7.142895] NET: Registered protocol family 29
[ 7.149462] can: raw protocol (rev 20120528)
[ 7.155837] can: broadcast manager protocol (rev 20120528 t)
[ 7.163611] can: netlink gateway (rev 20130117) max_hops=1
[ 7.171235] NET: Registered protocol family 35
[ 7.177963] 8021q: 802.1Q VLAN Support v1.8
[ 7.184550] NET: Registered protocol family 37
[ 7.191014] Key type dns_resolver registered
[ 7.197245] NET: Registered protocol family 41
[ 7.204940] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 7.241320] Registering SWP/SWPB emulation handler
[ 7.248074] last reset is due to power on reset
[ 7.248074]
[ 7.257851] Disabling clocks left on by bootloader:
[ 7.264646] audio_2x
[ 7.269045] audio
[ 7.273110] audio4
[ 7.277191] audio3
[ 7.281194] audio2
[ 7.285130] audio1
[ 7.289036] audio0
[ 7.292935] hdmi_audio
[ 7.297082] entropy
[ 7.300940] dsi2-fixed
[ 7.305023] dsi1-fixed
[ 7.309087] mipi-cal-fixed
[ 7.313434] nor
[ 7.316825] trace
[ 7.320336] sdmmc3_ddr
[ 7.324230] sdmmc1_ddr
[ 7.328118] cclk_lp
[ 7.331711] pll_x_out0
[ 7.335482] pll_u_12M
[ 7.339125] pll_m_out1
[ 7.342915] tegra_dvfs: vdd_cpu connected to regulator
[ 7.349225] tegra_dvfs: vdd_core connected to regulator
[ 7.355628] tegra_dvfs: vdd_gpu connected to regulator
[ 7.363291] cpu_cold cooling device is registered
[ 7.369203] cpu_hot cooling device is registered
[ 7.369304] Tegra CPU DFLL is initialized with use_dfll = 1
[ 7.369362] CPU rate: 696 MHz
[ 7.552814] tegra dvfs: tegra sysfs cap interface is initialized
[ 7.559827] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 7.567793] tegra_actmon.emc: Completed initialization (0)
[ 7.574554] tegra_actmon.avp: Completed initialization (0)
[ 7.581098] tegra_mon.cpu_emc: Completed initialization (0)
[ 7.590167] VCC_USBH(2A|2C|2D|3|4): incomplete constraints, leaving on
[ 7.597789] +V1.05_AVDD_HDMI_PLL: incomplete constraints, leaving on
[ 7.605356] +V1.8_VPP_FUSE: incomplete constraints, leaving on
[ 7.612361] as3722-ldo7: incomplete constraints, leaving on
[ 7.619195] VDDIO_SDMMC3: incomplete constraints, leaving on
[ 7.626155] as3722-ldo5: incomplete constraints, leaving on
[ 7.633066] VDDIO_SDMMC1: incomplete constraints, leaving on
[ 7.640067] as3722-sd3: incomplete constraints, leaving on
[ 7.646938] regulator-dummy: incomplete constraints, leaving on
[ 7.654904] file system registered
[ 7.660599] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 7.669032] android_usb gadget: Number of LUNs=1
[ 7.675206] lun0: LUN: removable file: (no medium)
[ 7.682050] android_maxim14675_set_voltage: max_voltage (vbus) = 5000
[ 7.690182] android_usb gadget: android_usb ready
[ 7.696578] tegra-udc: bind to driver android_usb
[ 7.703172] of_get_named_gpio_flags exited with status 235
[ 7.703195] of_get_named_gpio_flags exited with status 117
[ 7.703244] gpio wake14 for gpio=235
[ 7.708639] gpio wake0 for gpio=117
[ 7.714035] input: gpio-keys.4 as /devices/platform/gpio-keys.4/input/input0
[ 7.723644] as3722-rtc as3722-rtc.1: setting system clock to 2000-01-01 00:00:11 UTC (946684811)
[ 7.736906] ALSA device list:
[ 7.741244] #0: Toradex Apalis TK1 SGTL5000
[ 7.746998] #1: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 8.333108] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 425909
[ 8.333331] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 425902
[ 8.333422] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 425901
[ 8.333511] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 709607
[ 8.333650] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 425890
[ 8.333765] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 425854
[ 8.333855] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 709627
[ 8.333939] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 709629
[ 8.334069] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 390921
[ 8.334156] EXT4-fs (mmcblk0p2): 9 orphan inodes deleted
[ 8.341436] EXT4-fs (mmcblk0p2): recovery complete
[ 8.355047] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 8.366948] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 8.376064] devtmpfs: mounted
[ 8.381410] Freeing unused kernel memory: 456K (c09ed000 - c0a5f000)
[ 8.648463] init: plymouth-upstart-bridge main process (148) terminated with status 1
[ 8.660923] init: plymouth-upstart-bridge main process ended, respawning
[ 8.711987] init: plymouth-upstart-bridge main process (158) terminated with status 1
[ 8.724374] init: plymouth-upstart-bridge main process ended, respawning
[ 8.738234] init: ureadahead main process (151) terminated with status 5
[ 8.776662] init: plymouth-upstart-bridge main process (162) terminated with status 1
[ 8.789292] init: plymouth-upstart-bridge main process ended, respawning
[ 9.069778] usb 1-1: new high-speed USB device number 2 using tegra-ehci
[ 9.196552] usb 1-1: New USB device found, idVendor=0483, idProduct=5740
[ 9.206922] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.218553] usb 1-1: Product: STM32 Virtual ComPort in HS Mode
[ 9.229374] usb 1-1: Manufacturer: STMicroelectronics
[ 9.240243] usb 1-1: SerialNumber: 327433703136
[ 10.182776] init: idmapd main process (314) terminated with status 1
[ 10.182878] init: idmapd main process ended, respawning
[ 10.186482] systemd-udevd[345]: starting version 204
[ 10.599533] Tegra cpuquiet clusterswitch enabled
[ 10.726294] vi vi.0: vi_probe: ++
[ 10.732351] vi vi.0: initialized
[ 10.735051] vi vi.1: vi_probe: ++
[ 10.739774] vi vi.1: initialized
[ 10.749652] systemd-udevd[412]: renamed network interface eth0 to eth1
[ 10.830102] of_get_named_gpio_flags exited with status 222
[ 10.830188] of_get_named_gpio_flags exited with status 178
[ 10.830245] of_get_named_gpio_flags exited with status 74
[ 10.891421] gpio wake34 for gpio=82
[ 10.891641] gpio wake23 for gpio=69
[ 10.891661] gpio wake33 for gpio=72
[ 10.914484] tegra-xhci tegra-xhci: Firmware File: tegra_xusb_firmware (134656 Bytes)
[ 10.915552] tegra-xhci tegra-xhci: Firmware DMA Memory: dma 0x80080000 mapped 0xf0323000 (134656 Bytes)
[ 10.922582] tegra-xhci tegra-xhci: XUSB device id = 0xfa3 (T124+)
[ 10.923947] apalis-tk1-k20 spi1.1: Apalis TK1 K20 MFD driver. Firmware version 1.1.
[ 10.925514] of_get_named_gpio_flags exited with status 238
[ 10.939744] Bluetooth: Core ver 2.16
[ 10.939786] NET: Registered protocol family 31
[ 10.939791] Bluetooth: HCI device and connection manager initialized
[ 10.939808] Bluetooth: HCI socket layer initialized
[ 10.939817] Bluetooth: L2CAP socket layer initialized
[ 10.939840] Bluetooth: SCO socket layer initialized
[ 10.959410] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 10.959433] Bluetooth: BNEP socket layer initialized
[ 10.975738] tegra-xhci tegra-xhci: Firmware timestamp: 2014-09-16 02:10:07 UTC, Falcon state 0x20
[ 10.975802] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 10.975823] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 2
[ 10.976743] tegra-xhci tegra-xhci: irq 71, io mem 0x70090000
[ 10.976816] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 10.976823] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.976830] usb usb2: Product: Nvidia xHCI Host Controller
[ 10.976855] usb usb2: Manufacturer: Linux 3.10.40-2.8.3+g6c533d3 tegra-xhci
[ 10.976863] usb usb2: SerialNumber: tegra-xhci
[ 10.977189] xHCI xhci_add_endpoint called for root hub
[ 10.977195] xHCI xhci_check_bandwidth called for root hub
[ 10.977282] hub 2-0:1.0: USB hub found
[ 10.977302] hub 2-0:1.0: 6 ports detected
[ 10.977490] cdc_acm 1-1:1.0: This device cannot do calls on its own. It is not a modem.
[ 10.990193] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 10.990208] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 3
[ 10.990282] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
[ 10.990288] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.990294] usb usb3: Product: Nvidia xHCI Host Controller
[ 10.990318] usb usb3: Manufacturer: Linux 3.10.40-2.8.3+g6c533d3 tegra-xhci
[ 10.990323] usb usb3: SerialNumber: tegra-xhci
[ 10.990619] xHCI xhci_add_endpoint called for root hub
[ 10.990626] xHCI xhci_check_bandwidth called for root hub
[ 10.990750] hub 3-0:1.0: USB hub found
[ 10.990763] hub 3-0:1.0: 2 ports detected
[ 10.993890] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
[ 10.994891] usbcore: registered new interface driver cdc_acm
[ 10.994898] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 11.004887] Wake58 for irq=81
[ 11.004901] Wake40 for irq=53
[ 11.004905] Wake42 for irq=53
[ 11.004917] Wake41 for irq=129
[ 11.004922] Wake43 for irq=129
[ 11.016622] Bluetooth: RFCOMM socket layer initialized
[ 11.016630] Bluetooth: RFCOMM ver 1.11
[ 11.064916] init: idmapd main process (479) terminated with status 1
[ 11.064952] init: idmapd main process ended, respawning
[ 11.099725] input: apalis-tk1-k20-ts as /devices/platform/spi-tegra114.1/spi_master/spi1/spi1.1/apalis-tk1-k20-ts/input/input1
[ 11.102210] apalis-tk1-k20-can apalis-tk1-k20-can.0: probed 0
[ 11.102482] apalis-tk1-k20-can apalis-tk1-k20-can.1: probed 1
[ 11.107672] gpiochip_find_base: found new base at 856
[ 11.107756] gpiochip_add: registered GPIOs 856 to 1015 on device: generic
[ 11.317128] init: idmapd main process (523) terminated with status 1
[ 11.317160] init: idmapd main process ended, respawning
[ 11.533953] init: idmapd main process (602) terminated with status 1
[ 11.533977] init: idmapd main process ended, respawning
[ 11.662152] init: idmapd main process (631) terminated with status 1
[ 11.662173] init: idmapd main process ended, respawning
[ 11.703745] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 11.703757] 8021q: adding VLAN 0 to HW filter on device eth1
[ 11.741312] init: idmapd main process (656) terminated with status 1
[ 11.741341] init: idmapd main process ended, respawning
[ 11.856595] init: idmapd main process (698) terminated with status 1
[ 11.856618] init: idmapd main process ended, respawning
[ 11.925720] tegra-i2c tegra12-i2c.0: --- register dump for debugging ----
[ 11.933189] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 11.938990] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 11.949513] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 11.970095] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 11.978978] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 11.987083] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 11.993180] tegra-i2c tegra12-i2c.0: msg->len - 2
[ 11.998584] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 12.004333] tegra-i2c tegra12-i2c.0: next_msg->len - 7
[ 12.010145] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 12.010149] tegra-i2c tegra12-i2c.0: buf_remaining - 7
[ 12.010156] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x004a, data 0x00
[ 12.010221] atmel_mxt_ts 0-004a: __mxt_read_reg: i2c transfer failed (-110)
[ 12.069007] init: idmapd main process (736) terminated with status 1
[ 12.069030] init: idmapd main process ended, respawning
[ 12.276095] init: idmapd main process (801) terminated with status 1
[ 12.276120] init: idmapd main process ended, respawning
[ 12.419153] init: failsafe main process (778) killed by TERM signal
[ 12.544350] init: idmapd main process (846) terminated with status 1
[ 12.544374] init: idmapd main process ended, respawning
[ 12.552989] init: Failed to obtain startpar-bridge instance: Unknown parameter: INSTANCE
[ 12.813140] init: idmapd main process (879) terminated with status 1
[ 12.813167] init: idmapd respawning too fast, stopped
[ 13.009749] tegra-i2c tegra12-i2c.0: --- register dump for debugging ----
[ 13.017807] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 13.023932] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 13.031666] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 13.031672] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800080
[ 13.031676] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 13.031681] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x2
[ 13.031685] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 13.031688] tegra-i2c tegra12-i2c.0: is_msg_write - 0
[ 13.031710] tegra-i2c tegra12-i2c.0: buf_remaining - 1
[ 13.031717] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x0024, data 0x00
[ 13.031784] atmel_mxt_ts 0-004a: mxt_bootloader_read: i2c recv failed (-110)
[ 13.031787] atmel_mxt_ts 0-004a: Trying alternate bootloader address
[ 13.586574] init: plymouth-upstart-bridge main process ended, respawning
[ 14.031747] tegra-i2c tegra12-i2c.0: --- register dump for debugging ----
[ 14.041905] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 14.051002] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 14.060782] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 14.068840] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800080
[ 14.076689] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 14.086381] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x2
[ 14.097227] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 14.109106] tegra-i2c tegra12-i2c.0: is_msg_write - 0
[ 14.114724] tegra-i2c tegra12-i2c.0: buf_remaining - 1
[ 14.120157] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x0026, data 0x00
[ 14.128121] atmel_mxt_ts 0-004a: mxt_bootloader_read: i2c recv failed (-110)
[ 14.135427] atmel_mxt_ts: probe of 0-004a failed with error -110
[ 14.244618] igb 0000:01:00.0 eth1: igb: eth1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
[ 14.244812] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 14.361421] tegradc tegradc.0: switching framebuffer to 640x480
[ 14.361427] tegradc tegradc.0: Calculated sync href=0 vref=1
[ 14.361433] tegradc tegradc.0: using mode 640x480 pclk=25175000 href=0 vref=1
[ 14.362951] tegradc tegradc.0: nominal-pclk:25175000 parent:25125000 div:1.0 pclk:25125000 24923250~27440750
[ 14.567920] init: plymouth-stop pre-start process (1285) terminated with status 1
[ 17.290778] HDMI: No HDMI device connected
[ 19.054972] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 21.107824] tegra-xhci tegra-xhci: Firmware timestamp: 2014-09-16 02:10:07 UTC, Falcon state 0x20
[ 21.439851] usb 2-3: new high-speed USB device number 2 using tegra-xhci
[ 21.452223] usb 2-3: New USB device found, idVendor=12d1, idProduct=14fe
[ 21.452233] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 21.452239] usb 2-3: Product: HUAWEI_MOBILE
[ 21.452244] usb 2-3: Manufacturer: HUAWEI_MOBILE
[ 21.452250] usb 2-3: SerialNumber: 0123456789ABCDEF
[ 21.494554] usb-storage 2-3:1.0: USB Mass Storage device detected
[ 21.510045] scsi2 : usb-storage 2-3:1.0
[ 21.802836] usb 1-1: reset high-speed USB device number 2 using tegra-ehci
[ 22.518284] scsi 2:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
[ 22.544194] sr0: scsi-1 drive
[ 22.544227] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 22.552166] sr 2:0:0:0: Attached scsi CD-ROM sr0
[ 22.565184] sr 2:0:0:0: Attached scsi generic sg0 type 5
[ 22.571100] scsi 2:0:0:1: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
[ 22.571696] sd 2:0:0:1: Attached scsi generic sg1 type 0
[ 22.576785] sd 2:0:0:1: [sda] Attached SCSI removable disk
[ 22.772042] usb 2-3: USB disconnect, device number 2
[ 23.700498] usb 2-3: new high-speed USB device number 3 using tegra-xhci
[ 23.718752] usb 2-3: New USB device found, idVendor=12d1, idProduct=1506
[ 23.718810] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 23.718978] usb 2-3: Product: HUAWEI_MOBILE
[ 23.719019] usb 2-3: Manufacturer: HUAWEI_MOBILE
[ 23.819557] usb-storage 2-3:1.3: USB Mass Storage device detected
[ 23.823733] scsi3 : usb-storage 2-3:1.3
[ 23.828280] usb-storage 2-3:1.4: USB Mass Storage device detected
[ 23.830343] scsi4 : usb-storage 2-3:1.4
[ 23.906104] usbcore: registered new interface driver option
[ 23.906588] usbserial: USB Serial support registered for GSM modem (1-port)
[ 23.906696] option 2-3:1.0: GSM modem (1-port) converter detected
[ 23.907865] usb 2-3: GSM modem (1-port) converter now attached to ttyUSB0
[ 23.907925] option 2-3:1.1: GSM modem (1-port) converter detected
[ 23.908153] usb 2-3: GSM modem (1-port) converter now attached to ttyUSB1
[ 24.832179] scsi 3:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
[ 24.838931] scsi 4:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
[ 24.839362] sd 4:0:0:0: Attached scsi generic sg0 type 0
[ 24.841979] sd 4:0:0:0: [sda] Attached SCSI removable disk
[ 24.853778] sr0: scsi-1 drive
[ 24.854194] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 24.854320] sr 3:0:0:0: Attached scsi generic sg1 type 5
[ 33.816567] option 2-3:1.2: GSM modem (1-port) converter detected
[ 33.816818] usb 2-3: GSM modem (1-port) converter now attached to ttyUSB2
[ 40.490970] PPP generic driver version 2.4.2
[ 41.013272] PPP BSD Compression module registered
[ 41.027767] PPP Deflate Compression module registered
[ 198.694462] NOHZ: local_softirq_pending 100
[ 725.097917] Unable to handle kernel NULL pointer dereference at virtual address 00000015
[ 725.107345] pgd = e5efc000
[ 725.110119] [00000015] *pgd=a5c49003, *pmd=a5ee8003, *pte=00000000
[ 725.116401] Internal error: Oops: 207 [#1] PREEMPT SMP ARM
[ 725.121876] Modules linked in: ppp_deflate bsd_comp ppp_async ppp_generic slhc option usb_wwan joydev gpio_apalis_tk1_k20 apalis_tk1_k20_adc apalis_tk1_k20_can apalis_tk1_k20_ts rfcomm cdc_acm bnep bluetooth atmel_mxt_ts apalis_tk1_k20 nvhost_vi
[ 725.125832] CPU: 2 PID: 2431 Comm: pppd Not tainted 3.10.40-2.8.3+g6c533d3 #1
[ 725.125836] task: e7ba8040 ti: e5ef4000 task.ti: e5ef4000
[ 725.125844] PC is at tty_ldisc_close+0x3c/0x58
[ 725.125847] LR is at tty_ldisc_close+0x38/0x58
[ 725.125851] pc : [<c039224c>] lr : [<c0392248>] psr: 60010013
[ 725.125851] sp : e5ef5e20 ip : 00000000 fp : 00000000
[ 725.125854] r10: 00000000 r9 : 00000000 r8 : ed681a18
[ 725.125857] r7 : 00000000 r6 : e6f1a3c0 r5 : e6f1a3c0 r4 : ed681a00
[ 725.125859] r3 : 00000001 r2 : 0004020a r1 : ed681b24 r0 : 00000000
[ 725.125863] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 725.125867] Control: 30c5387d Table: a5efc000 DAC: 55555555
[ 725.125869]
[ 725.125869] PC: 0xc03921cc:
[ 725.125870] 21cc e8bd4070 ea0005f9 e92d4070 e52de004 e8bd4000 e2805064 e1a04000 e1a06001
[ 725.125879] 21ec e1a00005 eb0e332e e5c46090 e1a00005 eb0e3350 e3a03000 e5843174 e5843138
[ 725.125890] 220c e8bd8070 e92d4070 e52de004 e8bd4000 e1a04000 e5903124 e1a05001 e3130b02
[ 725.125900] 222c 1a000002 e3a01f72 e59f0028 ebf31897 e2841f49 e3a0000b ebfca1c0 e5953000
[ 725.125911] 224c e5933014 e3530000 08bd8070 e1a00004 e8bd4070 e12fff13 c09076f1 e92d4010
[ 725.125921] 226c e52de004 e8bd4000 e2804f49 e3a00016 e1a01004 ebfca1b1 e1a01004 e3a00009
[ 725.125929] 228c ebfcab6e e1a01004 e3a0000a ebfca1ab e3a03000 e3a02001 e3a01003 e59f0004
[ 725.125940] 22ac e8bd4010 eaf3c70b c0b0abc8 e92d4030 e24dd01c e52de004 e8bd4000 e5903030
[ 725.125951]
[ 725.125951] LR: 0xc03921c8:
[ 725.125951] 21c8 e1a00004 e8bd4070 ea0005f9 e92d4070 e52de004 e8bd4000 e2805064 e1a04000
[ 725.125960] 21e8 e1a06001 e1a00005 eb0e332e e5c46090 e1a00005 eb0e3350 e3a03000 e5843174
[ 725.125969] 2208 e5843138 e8bd8070 e92d4070 e52de004 e8bd4000 e1a04000 e5903124 e1a05001
[ 725.125977] 2228 e3130b02 1a000002 e3a01f72 e59f0028 ebf31897 e2841f49 e3a0000b ebfca1c0
[ 725.125988] 2248 e5953000 e5933014 e3530000 08bd8070 e1a00004 e8bd4070 e12fff13 c09076f1
[ 725.126000] 2268 e92d4010 e52de004 e8bd4000 e2804f49 e3a00016 e1a01004 ebfca1b1 e1a01004
[ 725.126009] 2288 e3a00009 ebfcab6e e1a01004 e3a0000a ebfca1ab e3a03000 e3a02001 e3a01003
[ 725.126022] 22a8 e59f0004 e8bd4010 eaf3c70b c0b0abc8 e92d4030 e24dd01c e52de004 e8bd4000
[ 725.126034]
[ 725.126034] SP: 0xe5ef5da0:
[ 725.126035] 5da0 e5ef5e08 e5ef5e0c e5ef4000 00000002 00000000 c071f678 c0a656c0 00000001
[ 725.126048] 5dc0 e7ba8040 c039224c 60010013 ffffffff e5ef5e0c c000e158 00000000 ed681b24
[ 725.126059] 5de0 0004020a 00000001 ed681a00 e6f1a3c0 e6f1a3c0 00000000 ed681a18 00000000
[ 725.126070] 5e00 00000000 00000000 00000000 e5ef5e20 c0392248 c039224c 60010013 ffffffff
[ 725.126081] 5e20 e6b95380 ed681a00 e6f1a3c0 c0392c14 00000047 ed681b24 c038af2c 200f0013
[ 725.126092] 5e40 ffffffff e5ef5e8c ed681a00 e6be3740 00000000 c0390f90 7fffffff ed681a00
[ 725.126102] 5e60 7fffffff 0004d700 ed681a00 c0390f90 00005423 0004d700 ed681a00 00000000
[ 725.126114] 5e80 ed681a00 00005423 0004d700 ed681a00 e6be3740 00005418 00000008 c038dd2c
[ 725.126128]
[ 725.126128] R1: 0xed681aa4:
[ 725.126130] 1aa4 00002580 00002580 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126144] 1ac4 00000000 00000000 00000000 00000000 00000000 00000000 55797474 00314253
[ 725.126158] 1ae4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126173] 1b04 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126186] 1b24 0004020a 00000002 00000000 00000000 00000000 00010000 00000000 00000000
[ 725.126199] 1b44 00000000 00000000 a4f3a4f3 ed681b50 ed681b50 03410341 ed681b5c ed681b5c
[ 725.126216] 1b64 00000000 ed681b68 ed681b68 c038bc8c e5e2c000 eaf8b000 e8d9f148 e5e4ccc8
[ 725.126232] 1b84 00010000 ea832000 00000400 ffffffe0 ed681b94 ed681b94 c038c528 eaf8b004
[ 725.126246]
[ 725.126246] R4: 0xed681980:
[ 725.126248] 1980 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126262] 19a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126276] 19c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126290] 19e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126304] 1a00 00005401 00000003 ed805200 ed04d7c0 c07853bc 00000001 00000000 00000000
[ 725.126319] 1a20 ed681a20 ed681a20 e7ba8040 00000000 e6b95d80 00000001 00000000 ed681a3c
[ 725.126333] 1a40 ed681a3c 00000000 00000000 ffffffff 00010001 ea6c7dfc ea6c7dfc e7ba8040
[ 725.126347] 1a60 00000000 00000001 00000000 ed681a6c ed681a6c 00000000 00000000 00020002
[ 725.126361]
[ 725.126361] R5: 0xe6f1a340:
[ 725.126363] a340 001a001a e6f1a344 e6f1a344 00000000 00000000 e67040f8 00000000 00000000
[ 725.126376] a360 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126387] a380 e8d9fdc0 e6d9a500 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126397] a3a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126407] a3c0 00000000 00000001 00000001 00000000 00000000 00000000 00000000 00000000
[ 725.126420] a3e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126432] a400 f65b4000 f65b7000 00000001 e5d9488d 00000000 00000000 e710ee98 e5d94898
[ 725.126443] a420 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126453]
[ 725.126453] R6: 0xe6f1a340:
[ 725.126454] a340 001a001a e6f1a344 e6f1a344 00000000 00000000 e67040f8 00000000 00000000
[ 725.126463] a360 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126474] a380 e8d9fdc0 e6d9a500 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126486] a3a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126495] a3c0 00000000 00000001 00000001 00000000 00000000 00000000 00000000 00000000
[ 725.126505] a3e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126516] a400 f65b4000 f65b7000 00000001 e5d9488d 00000000 00000000 e710ee98 e5d94898
[ 725.126526] a420 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126537]
[ 725.126537] R8: 0xed681998:
[ 725.126539] 1998 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126550] 19b8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126560] 19d8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 725.126570] 19f8 00000000 00000000 00005401 00000003 ed805200 ed04d7c0 c07853bc 00000001
[ 725.126579] 1a18 00000000 00000000 ed681a20 ed681a20 e7ba8040 00000000 e6b95d80 00000001
[ 725.126589] 1a38 00000000 ed681a3c ed681a3c 00000000 00000000 ffffffff 00010001 ea6c7dfc
[ 725.126600] 1a58 ea6c7dfc e7ba8040 00000000 00000001 00000000 ed681a6c ed681a6c 00000000
[ 725.126614] 1a78 00000000 00020002 00000005 00000000 000004bd 000
