i am trying to configure my environment to compile C++ project with PGI Compiller (pgc++) on Win7x64bit.
So i download and install PGI Accelerator Workstation for win64 ( pgiws64-164.exe ).
And both consols PGIBash(64) and PGICmd(64) give me this error:
PGI Workstation 16.4 (64)
PGI$ pgc++
bash: pgc++: command not found
Is it posible that pgc++ works only in Linux and do not available in Windows ?
Maybe you already have workaround for this case ?
Any help will be appreciated.
There has never been a pgc++ on Windows. What was there was
a previous product pgcpp which was renamed from pgCC because Windows
is case insensitive.
The pgcpp product has been discontinued on all of the PGI
products. We recommend Visual C++ as an alternative on Windows, since
there is only a PGI C compiler on Windows.
So am i understand this right ?
There is no way i can use PGI to compile C++ code on windows.
Only on UNIX system.
What do you mean by: “We recommend Visual C++ as an alternative on Windows” ?
I shell compile C++ code with PGI C Compiller ?
