I’ve recently downloaded a trial version of the PGI Workstation 15.7 for C/C++ and Fortran. All the commands (pgcc, pgfortran…) work fine, however, it doesn’t recognize the pgc++ command, so I can´t compile and parallelize my .cpp. I’ve tried to modify the instalation and choose the PGI C++ compiler (both) but that had made the PGI program to crash… Now it doesn’t recognize any command previously mentioned…
Regards.
Hi alvarobaq,
What OS are you using? pgc++ is not available on Windows.
If you are on Linux or Mac, please post more details such as the exact error message you’re seeing and if the pgc++ binary is in the PGI install directory.
Not knowing what you did, it’s probably best to simply reinstall.
I’ve solved it. The command in Windows was pgcpp. Thanks for your response.
