Hi everyone,
i have problem with PGI for Win64 (evaluation edition): after compiling creates pgcpp only a .TI file and pgf95 nothing. Can someone help me?
My system:
Windows XP Professional x64 Edition
Microsoft Platform SDK for Windows Server 2003 R2
PGI Workstation 6.1-4
BEA JRockit 5.0 R26 JRE for Intel EM64T & AMD64
I’ve seen a similar issue when compiling from the command window (not the bash shell) because Windows resolves “pgf95” to be “pgf95.rc” instead of “pgf95.exe”. When I use “pgf95.exe” instead, everything compiles fine. If this doesn’t work, can you try compiling with “-v” and post the output?
Hi Mat,
i have found the problem: with bash shell PGIW conflicts somehow with Cygwin, just remove Cygwin (in the registry too) then everything ok.
Thanks,
Long
