Hello!
I just installed PGI CE 18.10, but the PGI bash doesn’t seem to work. A screen flashes briefly, but then vanishes.
Any suggestions much appreciated.
Thanks,
Erin
PS Windows 10 64 bit operating system.
Hello!
Thanks,
Erin
Hi Erin,
Which “bat” file are you using?
“pgi_env.bat” will do this since it’s used to setup the PGI environment from an already running DOS command and not meant to be run by itself.
-Mat
Hi Mat:
I tried pgi.bat. No good. And pgi_dos.bat doesn’t have good Linux-like commands, like the old PGICE had.
Thanks,
Erin
Hi Erin,
When you installed, did you choose to install Cygwin? If not, then this would be the cause since “pgi.bat” will call the “bash” provided by Cygwin.
Alternately, we do ship an old version of Cygwin so maybe there’s an incompatibility on your system. If so, then you might try installing Cygwin directly from https://www.cygwin.com/.
Hope this helps,
Mat
Great! This is a big help.
Thank you!
Sincerely,
Erin
