I am fairly new to using Isaac Sim and I don’t quite understand where the error comes from. I was checking posts on the forum but I couldn’t find a solution for my problem. I am currently working on a research project on my university and I need to use Isaac Sim, ZED Stereo camera and THK Seed Noid robot to perform floor space segmentation. I was trying to import the robot’s URDF file on Isaac SIM by following this tutorial https://docs.omniverse.nvidia.com/isaacsim/latest/advanced_tutorials/tutorial_advanced_import_urdf.html#importing-urdf-using-python . However I did some changes to the python file and it looks like this:
Copyright (c) 2020-2023, NVIDIA CORPORATION. All rights reserved.
NVIDIA CORPORATION and its licensors retain all intellectual property
and proprietary rights in and to this software, related documentation
and any modifications thereto. Any use, reproduction, disclosure or
distribution of this software and related documentation without an express
license agreement from NVIDIA CORPORATION is strictly prohibited.
from omni.isaac.examples.base_sample import BaseSample
from omni.isaac.core.utils.extensions import get_extension_path_from_name
from omni.importer.urdf import _urdf
import omni.kit.commands
import omni.usd
Note: checkout the required tutorials at https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/overview.html
class HelloWorld(BaseSample):
def init(self) → None:
super().init()
return
def setup_scene(self):
world = self.get_world()
world.scene.add_default_ground_plane()
#Acquire the urdf interface
urdf_interface = _urdf.acquire_urdf_interface()
#Set the settings in the import configuration
import_config = _urdf.ImportConfig()
import_config.merge_fixed_joints = False
import_config.convex_decomp = True
import_config.fix_base = True
import_config.make_default_prim = True
import_config.self_collision = False
import_config.create_physics_scene = True
import_config.import_inertia_tensor = True
import_config.default_drive_strength = 1047.19751
import_config.default_position_drive_damping = 52.35988
import_config.default_drive_type = _urdf.UrdfJointTargetType.JOINT_DRIVE_POSITION
import_config.distance_scale = 1
import_config.density = 0.0
# Get the urdf file path
urdf_path = "/home/nakamuralab/Desktop/seed_r7_ros_pkg-master/seed_r7_description/typeg/noid.urdf"
# Finally import the robot
result, prim_path = omni.kit.commands.execute("URDFParseAndImportFile", urdf_path=urdf_path,
import_config=import_config,)
if not result:
print(f"Failed to import URDF file: {urdf_path}")
else:
print(f"URDF file imported successfully: {prim_path}")
return
async def setup_post_load(self):
return
async def setup_pre_reset(self):
return
async def setup_post_reset(self):
return
def world_cleanup(self):
return
if __name__ == "__main__":
sample = HelloWorld()
sample.run()
The URDF file of the robot is open source in this GitHub repo: seed_r7_ros_pkg/seed_r7_description/typeg/noid.urdf at master · seed-solutions/seed_r7_ros_pkg · GitHub
The error on Isaac SIM part is this:
2024-07-09 08:26:25 [73,576ms] [Error] [omni.physx.plugin] PhysX error: Illegal BroadPhaseUpdateData
, FILE /buildAgent/work/eb2f45c4acc808a0/physx/source/lowlevelaabb/src/BpBroadPhaseABP.cpp, LINE 4024
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/base_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/wheel_base_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/front_camera_base_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/rear_camera_base_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/wheels_base_laser_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/wheels_front_left_mecanum.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/wheels_front_right_mecanum.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/wheels_rear_left_mecanum.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/wheels_rear_right_mecanum.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/wheels_top_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/front_camera_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/rear_camera_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/lifter_base_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/front_camera_depth_optical_frame.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/front_camera_right_ir_frame.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/rear_camera_depth_optical_frame.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/rear_camera_right_ir_frame.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/leg_shank_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/leg_shank_link_dummy.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/leg_knee_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/leg_thigh_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/leg_thigh_link_dummy.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/leg_base_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/lifter_top_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/waist_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/hip_sphere_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/hip_center.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/body_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/chest_camera_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_shoulder_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/neck_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_shoulder_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/chest_camera_depth_optical_frame.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/chest_camera_right_ir_frame.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_shoulder_center.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/head_base_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_shoulder_center.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_upperarm_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/head_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_upperarm_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_elbow_virtual_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_elbow_virtual_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_elbow_virtual_link_dummy.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_elbow_virtual_link_dummy.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_elbow_middle_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_elbow_middle_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_elbow_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_elbow_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_forearm_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_forearm_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_wrist_center.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_wrist_center.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_wrist_r_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_wrist_r_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_hand_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_hand_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_eef_grasp_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_eef_pick_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_indexbase_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_thumb_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_eef_grasp_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_eef_pick_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_indexbase_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_thumb_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_indexmid_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_thumb_tip_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_indexmid_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_thumb_tip_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_indexend_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_indexend_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/l_index_tip_link.
2024-07-09 08:26:25 [73,561ms] [Warning] [omni.physx.plugin] Invalid PhysX transform detected for /SEED_Noid_Mover_typeG/r_index_tip_link.
I would appreciate an expert advice for my problem. Thank you in advance.
