Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
DRIVE OS Linux 6.0.6
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
I am working on the DRIVE AGX Orin with the official SDK sources, and we need to add a Trusted Execution Environment (TEE) to it. According to the NVIDIA DRIVE OS Linux SDK Developer Guide (PR-10720-6.0 _v6.0.9), I read about the PKCS#11 API to perform this task.
Following the README instructions, I successfully compiled and tested the example on a DRIVE AGX Orin running Linux. However, I encountered an error with the C_GetTokenInfo function in the pkcs11_init function while getting the token info:
Error:
TOKEN STATUS:
CKF_NVIDIA_SECURE_STORAGE_NOT_PROVISIONED
Investigating the error, I found that the token model being compared is NVPKCS11_CCPLEX_DYNAMIC_2_MODEL_NAME, which utilizes CCPLEX hardware as mentioned here. The documentation states that:
- To use a CCPLEX token, your application must also have access permission to all three GP-SE channels, by adding nvvse/Engines:0-2 custom abilities.
- For an application using a CCPLEX token to also have access to the TZ-SE (QNX only) cryptographic hardware, you add nvvse/Engines:3-5 custom abilities.
I noticed that the QNX section of the example code is the only one that specifies which GID is used (this adds custom abilities to the example, such as nvtzvault/crypto_ability nvvse/Engines:0-2):
Code:
#ifdef QNX /* TZ-SE and CKM_SHA256_HMAC not supported on Linux */
static CK_RV pkcs11_open_session_with_channel(CK_SESSION_HANDLE_PTR phSession, CK_SLOT_ID ccplex_slot_id, CK_NVIDIA_CHANNEL_HANDLE_PTR phChannel)
const CK_ULONG ulChannelIdSha = 7109U; /* This is the GID of device node /dev/nvvse/tzsha1 */
The README also provides details on GID management for QNX but not for Linux:
README
GNX instructions:
GID 6004 is to allow CCPLEX_DYNAMIC_2 token to be accessed. Other tokens will require different GIDs, these are listed in the PDK documentation.
The library will attempt to connect to all tokens when C_Initialize is called. You will see warnings about failing to connect to tokens that you do not have permission to use - these can be safely ignored.
- Conclusion
To run the sample app as non-root on a safety build, using nvvse and the CCPLEX_DYNAMIC_2 token:
iolauncher -U 45040:2281,2282,2283,7109,3000,3780,3790,6004,40002,40006,45011,45037,45040,45057,45066,45071,45112 \
-A nonroot,allow,able=nvvse/Engines:0-5 \
-A nonroot,allow,able=nvtzvault/pkcs11ks_dynamic_token_2_ability \
-A nonroot,allow,able=nvtzvault/crypto_ability \
-A nonroot,allow,able=nvsys/system_info \
-A nonroot,allow,able=Nvdvms/ClientCommGetState \
./pkcs11_reference_application
Linux Instructions:
To run the application, any command that uses pkcs11 needs to have tzvault privileges.
This can be done by adding the user temporarily to the tzvault group via sudo as follows:
sudo -u -g tzvault ./pkcs11_reference_application
Based on this information, it appears that the example is intended to run on QNX and not Linux if the TrustZone Secure Environment (TZ-SE) is required. The code and documentation indicate that TZ-SE is not supported on Linux.
So, I am writing to confirm whether TZ-SE is indeed not supported on Linux, or if I might be missing an initial setup or configuration? Additionally, do you know if there is a way to add GID custom abilities on Linux similar to the QNX README instructions?
