I have a prop called a curve wall with windows. It has 9 windows.
The 9 windows are all set to Clear Glass material.
I try setting the material for the Curved Wall prop itself, and it defaults to ‘Weaker Than Descendants’. If I switch it to stronger than descendants, the 9 windows inherit the material from the parent, and it looks like this.
It seems the only way I can keep the 9 windows is to Unparent the windows, which would mess everything up if I move them.
How am I supposed to set the windows to clear glass, and set the parent to another material without unparenting?
The window is set on inherit from parent, which I don’t want, and it can’t be changed unless I set the parent to weaker than descendants. I want an option instead of inherited, to independent.
