I have a Clevo P651RE6-G, mounting an Nvidia 1060 on Ubuntu Gnome 16.10, and to set maximum battery savings when not in AC I configured the xorg.conf as follows:
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "RegistryDwords" "PowerMizerEnable=0x1; PerfLevelSrc=0x2233; PowerMizerDefault=0x3"
EndSection
I found similar configurations online, however they also require the entry “PowerMizerLevel=0x3”, which does not work in my case.
Now I am just getting curious: what is the difference between “PowerMizerDefault” and “PowerMizerLevel”?
I found the following description online, however it not clear to me.
enables PowerMizer feature (0×0 would disable it instead). This entry may not be needed since in recent driver versions PowerMizer is enabled by default.
PerfLevelSrc=0x2222;
sets the governor approach. 0×2222 means fixed frequencies for both battery and AC mode.
PowerMizerLevel=0x3;
sets the current mode. 0×3 is the lowest, least power intensive mode.
PowerMizerDefault=0x3;
sets the default level on battery. 0×3 is the lowest, least power intensive mode.
PowerMizerDefaultAC=0x3"
sets the default level while with an AC plug. 0×3 is the lowest, least power intensive mode.
Is there anyone who knows the difference between “PowerMizerDefault” and “PowerMizerLevel”?
