Isaac Sim Version
4.2.0
Operating System
Ubuntu 22.04
Windows 11
GPU Information
- Model: RTX 3090Ti
- Driver Version: 550
Topic Description
Detailed Description
I would like to change the default unit for Preferences’ Default Meters Per Unit from 0.01m to 1m. Could you provide the path for USD Composer’s configuration files? Which specific file should I modify to make this change?
There is an issue where the default unit resets to 0.01 after restarting USD Composer.
Thank you for your attention.
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
@Happy_korea i am just another user, so feel free to defer to mod’s responses. there are a few locations where MPU can be adjusted; but, since you specifically asked for the preferences configs for Composer 2023.2.5, you can try opening and edit ...\2023.2.5\app\omni.create.kit
in any text editor.
unfortunately i don’t have Composer in front of me, so i am won’t be able to give you the exact snippet. however, there’s an older thread in which the steps to configure the preferences are outlined that may be relevant - Save Preferences - #5 by Simplychenable
and just to add, you may have to turn off the Force Settings
option in order to allow custom settings to take place.
