Problem with installing 'Cache' and 'Nucleus'
I’ve tried to install Isaac Sim through Omniverse Launcher, but there seems problems with ‘Cache’ and ‘Nucleus’ installation. Whenever I tried to access ‘Exchange’ tab for installing ‘Cache’ in the launcher, I get ‘Failed to Fetch’ error. Log is as follows. Is there any suggestion for the problem? Can you specify exact ‘URLs’ or ‘Ports’ for firewall exception? Thanks in advance!
[2023-03-28 10:11:48.437] [error] (node:10000) UnhandledPromiseRejectionWarning: Error: ENOSPC: System limit for number of file watchers reached, watch ‘/home/dongwoo/.nvidia-omniverse/config/Nucleus Navigator/ports.toml’
at FSWatcher. (node:internal/fs/watchers:244:19)
at Object.watch (node:fs:2264:34)
at N (/tmp/.mount_omnivePf8JYk/resources/app.asar/dist/main.js:220:5966)
at P (/tmp/.mount_omnivePf8JYk/resources/app.asar/dist/main.js:220:6162)
at e.exports._watchWithNodeFs (/tmp/.mount_omnivePf8JYk/resources/app.asar/dist/main.js:220:7690)
at e.exports._handleFile (/tmp/.mount_omnivePf8JYk/resources/app.asar/dist/main.js:220:8366)
at e.exports._addToNodeFs (/tmp/.mount_omnivePf8JYk/resources/app.asar/dist/main.js:220:11449)
at async /tmp/.mount_omnivePf8JYk/resources/app.asar/dist/main.js:89:50227
at async Promise.all (index 0)
[2023-03-28 10:11:48.437] [error] (node:10000) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v19.8.1 Documentation). (rejection id: 265)
[2023-03-28 10:11:48.437] [error] (node:10000) UnhandledPromiseRejectionWarning: TypeError: Cannot read properties of undefined (reading ‘close’)
at P (/tmp/.mount_omnivePf8JYk/resources/app.asar/dist/main.js:220:6177)
[2023-03-28 10:11:48.437] [error] (node:10000) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v19.8.1 Documentation). (rejection id: 266)
[2023-03-28 10:11:53.440] [debug] Port watcher has stopped: Error: ENOSPC: System limit for number of file watchers reached, watch ‘/home/dongwoo/.nvidia-omniverse/config/Nucleus Navigator/ports.toml’
[2023-03-28 10:11:53.441] [debug] Restarting the port watcher in 5 seconds…
[2023-03-28 10:11:53.442] [error] (node:10000) UnhandledPromiseRejectionWarning: Error: ENOSPC: System limit for number of file watchers reached, watch ‘/home/dongwoo/.nvidia-omniverse/config/Nucleus Navigator/ports.toml’
[2023-03-28 10:11:53.442] [error] (node:10000) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v19.8.1 Documentation). (rejection id: 267)
[2023-03-28 10:11:53.443] [error] (node:10000) UnhandledPromiseRejectionWarning: TypeError: Cannot read properties of undefined (reading ‘close’)
[2023-03-28 10:11:53.443] [error] (node:10000) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v19.8.1 Documentation). (rejection id: 268)
[2023-03-28 10:11:58.447] [debug] Port watcher has stopped: Error: ENOSPC: System limit for number of file watchers reached, watch ‘/home/dongwoo/.nvidia-omniverse/config/Nucleus Navigator/ports.toml’
[2023-03-28 10:11:58.448] [debug] Restarting the port watcher in 5 seconds…
[2023-03-28 10:11:58.448] [error] (node:10000) UnhandledPromiseRejectionWarning: Error: ENOSPC: System limit for number of file watchers reached, watch ‘/home/dongwoo/.nvidia-omniverse/config/Nucleus Navigator/ports.toml’
[2023-03-28 10:11:58.449] [error] (node:10000) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v19.8.1 Documentation). (rejection id: 269)
[2023-03-28 10:11:58.449] [error] (node:10000) UnhandledPromiseRejectionWarning: TypeError: Cannot read properties of undefined (reading ‘close’)
[2023-03-28 10:11:58.450] [error] (node:10000) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v19.8.1 Documentation). (rejection id: 270)
[2023-03-28 10:12:03.454] [debug] Port watcher has stopped: Error: ENOSPC: System limit for number of file watchers reached, watch ‘/home/dongwoo/.nvidia-omniverse/config/Nucleus Navigator/ports.toml’
[2023-03-28 10:12:03.455] [debug] Restarting the port watcher in 5 seconds…
[2023-03-28 10:12:03.455] [error] (node:10000) UnhandledPromiseRejectionWarning: Error: ENOSPC: System limit for number of file watchers reached, watch ‘/home/dongwoo/.nvidia-omniverse/config/Nucleus Navigator/ports.toml’
[2023-03-28 10:12:03.456] [error] (node:10000) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v19.8.1 Documentation). (rejection id: 271)
[2023-03-28 10:12:03.456] [error] (node:10000) UnhandledPromiseRejectionWarning: TypeError: Cannot read properties of undefined (reading ‘close’)
[2023-03-28 10:12:03.457] [error] (node:10000) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v19.8.1 Documentation). (rejection id: 272)
[2023-03-28 10:12:08.462] [debug] Port watcher has stopped: Error: ENOSPC: System limit for number of file watchers reached, watch ‘/home/dongwoo/.nvidia-omniverse/config/Nucleus Navigator/ports.toml’
[2023-03-28 10:12:08.462] [debug] Restarting the port watcher in 5 seconds…
[2023-03-28 10:12:08.463] [error] (node:10000) UnhandledPromiseRejectionWarning: Error: ENOSPC: System limit for number of file watchers reached, watch ‘/home/dongwoo/.nvidia-omniverse/config/Nucleus Navigator/ports.toml’
[2023-03-28 10:12:08.463] [error] (node:10000) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v19.8.1 Documentation). (rejection id: 273)
[2023-03-28 10:12:08.464] [error] (node:10000) UnhandledPromiseRejectionWarning: TypeError: Cannot read properties of undefined (reading ‘close’)
[2023-03-28 10:12:08.464] [error] (node:10000) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v19.8.1 Documentation). (rejection id: 274)
[2023-03-28 10:13:04.090] [info] Omniverse Launcher 1.8.3 (production)
[2023-03-28 10:13:04.100] [info] Argv: /tmp/.mount_omniveTt9tSW/omniverse-launcher --no-sandbox
[2023-03-28 10:13:04.100] [info] Crash dumps directory: /home/dongwoo/.config/omniverse-launcher/Crashpad
[2023-03-28 10:13:04.211] [debug] Reset current installer.
[2023-03-28 10:13:04.228] [info] Running production web server.
[2023-03-28 10:13:04.235] [info] HTTP endpoints listening at http://localhost:33480
[2023-03-28 10:13:04.244] [debug] Sharing: false
[2023-03-28 10:13:04.312] [info] Started the Navigator web server on 127.0.0.1:34080.
[2023-03-28 10:13:04.960] [info] Saving omniverse-launcher.desktop file to /tmp/omniverse-launcher-VQT94V…
[2023-03-28 10:13:04.960] [debug]
[Desktop Entry]
Name=omniverse-launcher
Exec=“/home/dongwoo/Downloads/omniverse-launcher-linux.AppImage” --no-sandbox %u
Type=Application
Terminal=false
MimeType=x-scheme-handler/omniverse-launcher
[2023-03-28 10:13:05.008] [info] Saving omniverse.desktop file to /tmp/omniverse-launcher-wLJjTU…
[2023-03-28 10:13:05.009] [debug]
[Desktop Entry]
Type=Application
Terminal=false
[2023-03-28 10:13:05.117] [info] Logged in.
[2023-03-28 10:13:08.927] [info] Prompting user about untrusted certificate for https://ib.adnxs.com (net::ERR_CERT_AUTHORITY_INVALID)…
Hi @mclaren89. Welcome to the forums! I’ve moved this over to the Nucleus forum for now. Could you attach your logs here for Omniverse Launcher and Nucleus and Cache if you have any: How to Report an issue with Omniverse
