My configuration is:
Acer 4830TG
GeGorce GT 540M 2GB
Win7 Ultimate x64.
I’ve already had a problem with installing common drivers (but I’ve installed version 268.00).
Now I want to try CUDA programming but I can’t install developer driver (275.33).
I receive a message that contains:
“Ðтот графичеÑкий драйвер не обнаружил ÑовмеÑтимого графичеÑкого оборудованиє,
I would translate it like
“This graphic driver hasn’t found compatible graphic hardware”
Can I use common driver for CUDA programming?
If not, where can I find compatible driver compatible with my system.
This driver also should have Optimus technology support.
